RM European Auto Parts
Results 1 to 6 of 6
Thread: 2003 X5 A/c problem
    Apr 2019
    Nashville Tn
    2003 BMW X5
    2003 X5 A/c problem
    I have used the search feature and have not been able to find my problem. My a/c does not blow cold air on my 2003 X5 3.0. The clutch on the compressor does kick in when switched on and the compressor does continue to turn. The turn wheel on the dash is turned to the 3 blue dots. It is also full of freon. When you first turn it on, it starts to blows cool air just never gets cold like it use to. It also quits blowing cool air after a few minutes. I have notice that the auxiliary fan does not come on when the a/c is switched on, the auxiliary fan will run if I disconnect the pressure switch on the bottom a/c line, but then the compressor kicks out. Any help would be greatly appreciated!
    Thanks in advance
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Have you scanned for codes in the HVAC ECU? You may have several problems, and the best way to start is getting it scanned for codes.
    Did you fill the A/C system yourself? If so what tools/gauges did you use? Or was this done at a HVAC specialist shop?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Apr 2019
    Nashville Tn
    2003 BMW X5
    It has been full ever since we purchased it several years ago. Checked with a Freon add kit. I scanned the ECU and found no codes. Just not sure where to check from here. We purchased the car with 55K on it, it now has 120K and things are starting to fail, just yesterday the drivers door will not open using the door handle from the outside. Searched that and have found it to be a common problem. Wondering if it might be time to get rid of it?
    dworthy's Avatar
    Nov 2010
    Most hand-held scanner will only talk to the Engines Computer or DME in BMW speak (Thanks Marc).
    What are you using to scan the codes? There is a relative cheap way to talk to that car just using a laptop and an OBD-II cable called INPA. INPA will talk to every ECU in that car, and can perform basic testing plus show you live data.
    Darin
    Current:
    Past:
    M-Flight Member
    And by the way, checking your refrigerant level any other way that recovering it and measuring it, is highly inaccurate. There's a reason professionals don't just add Freon from a can with a crappy gauge on top. Your system may or may not have much Freon in it. Or could even have too much.
    Typically, the first step in any A/C problem is to have the system recovered (to measure how much was in it), vacuumed, and recharged to the proper level. I have been fixing BMW's professionally now for over 13 years. 80-90% of A/C problems have been fixed this way. It's usually low on refrigerant due to a leak.
    Jan 2016
    Ca
    2001 525it
    Yea I would go for an ac service first because the amount of freon in the system and high and low pressures are very important
  1. 2003 X5 keyless remote problem
    By Alfred1 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 06-15-2012, 10:08 AM
  2. 2003 X5 Rear Light Problem
    By mblair5 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-06-2011, 04:19 PM
  3. Specific Topic on 2003 X5 Problems?
    By doc540 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 11-15-2009, 06:30 PM
  4. 2003 x5 fuse 73 problem
    By tpcdan in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-13-2009, 05:10 AM
  5. 2003 X5 Start up problems
    By Sneeze99 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-10-2008, 11:51 PM
