Results 1 to 4 of 4
Thread: Frankenstein M52B25
    Jun 2018
    Central Florida
    98 323i vert
    Frankenstein M52B25
    So, I have a weird idea. I am getting ready to yank my M52B25 because I blew it. 25PSI from cylinder 6. I already have another engine that I’m going to toss into the car for the time being. My question is since I plan to build the B25 that’s coming out, would over boring the cylinders to 86.5mm for s52 pistons work? And on top of that, would my stock rotating assembly be able to work with it?
    Oct 2003
    Seattle
    99 M3
    You will have to check cylinder wall thickness for the bore change.
    The S52 has a longer stroke, so an S52 Crank would be required.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Obviously for bigger pistons with stock crank and stock rods you need custom pistons with different pin heights (or custom rods but no one does it that way). Buy an S52 crank and use 135 mm rods and bore to S52 piston spec and you are set. Many replacement S52 pistons come in slight overbore.
    Oct 2003
    Seattle
    99 M3
    …and generally, you should use as long of rod you can fit in any given block.
    https://www.enginebuildermag.com/201...ng-rod-ratios/
  1. The Horror - M5 Frankenstein
    By homerjsimpson in forum 1988 - 1996 (E34)
    Last Post: 03-30-2004, 01:32 AM
  2. Replies: 2
    Last Post: 08-27-2003, 12:28 PM
  3. Poor Frankenstein has to sell his Supra...
    By Frankenstein in forum Off-Topic
    Last Post: 03-13-2003, 06:23 PM
  4. Frankenstein....can it come to life?
    By StormShadow in forum 1991 - 1999 (E36)
    Last Post: 01-18-2002, 01:38 AM
