Results 1 to 5 of 5
Thread: Vorshlag camber plates top plate doesn’t rotate
    Nov 2018
    Virginia
    1998 e36 M3 Cosmos Black
    Hi so I just got some Billstien PSS9 coilovers and Vorshlag camber plates with oem perches. The issue is when I installed the plates on the struts and tightened the top nut the top plate doesn’t rotate at all and instead the strut shaft rotates inside the body of the strut. Is this normal for new coilovers or is it something I should look into more? Thanks!
    Apr 2017
    NJ
    1995 318ic
    The end of the piston shaft should have a hex or an inverted hex for an allen wrench or socket to hold the shaft while spinning on the nut, or just use an impact by itself
    Nov 2018
    Virginia
    I got it tight with the Allen key and a open ended wrench. The problem is after I did that the top plate of the camber plate won’t rotate without rotating the strut shaft as well.
    Nov 2018
    Virginia
    Bump
    Apr 2017
    NJ
    1995 318ic
    That sounds normal to me, the upper plate is still fixed to the strut tower with a nut right? The shaft should move freely inside the housing so it should be fine rotating slightly with the plates
  1. E36 WTB Vorshlag or Ground Control Camber/Caster top plates
    By HaLo in forum BMW Parts Wanted
    Last Post: 01-27-2012, 09:17 AM
  2. Brand new Vorshlag camber plates for an E46 BMW
    By VahramHS in forum Race Cars & Track Parts
    Last Post: 05-25-2007, 04:13 PM
  3. GB (Maybe): Vorshlag Camber plates
    By Matts M3 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 03-26-2007, 09:15 PM
  4. GB (Maybe): Vorshlag Camber plates
    By Matts M3 in forum 1983 - 1991 (E30)
    Last Post: 03-23-2007, 02:49 AM
  5. GB (Maybe): Vorshlag Camber plates
    By Matts M3 in forum 1987 - 1991 M3 (E30)
