Results 1 to 8 of 8
Thread: "check brake linings"
    Jan 2018
    Chicago
    01 540ia
    Changed my rear pads after getting the message on the dash, turned the ignition to second position for 30 sec and it cleared until after about a min of driving when I braked firmly. Next couple of times before I would start the car I would leave the ignition on and the message would go away until I braked firmly. Now the message won't clear at all, the sensor is connected tightly, made sure to hear that "click" when it went in. The part that clips onto the pads is easy to wiggle but is on there tight, should there not be any wiggle room? I'm not sure if it is a bad sensor as the message seemed to clear at first and would come on again when I braked hard, however nothing seems to have come loose.
    San Jose, CA
    1997 BMW 540i 6 speed
    Good idea to replace the sensor when replacing pads when the warning light comes on.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Always change the sensor when you do the pads.
    Jan 2018
    Chicago
    01 540ia
    Sorry should have specified, the sensor that's acting up is a new one from fcpeuro
    Apr 2018
    Socal
    00 528i, 01 540i
    It might be a bad sensor, if it's new. Or re-check your connection from sensor to car. New it should have low resistance and high resistance when it breaks the internal connection when it rubs against the rotor for too long.
    Feb 2014
    Alexandria, VA
    Did you not say that you installed the old sensor when you changed the pads? ?? ???
    NW suburban Chicago
    hiss by my window
    If the car "sees" an open condition in the sensor circuit the warning is illuminated. Your symptoms indicate a break in the wire or a bad connection. The supposedly sealed connectors have these little tiny damn pins that, at least in rustyworld where I live, love to melt away in spit of their sealed design and cozy little plastic houses in the wheel well. Have a good look at wires for pinches and the connector.
    Feb 2014
    Alexandria, VA
    I splat a huge load of dialectic grease in there every time I replace the sensors, and splat more in whenever I get a chance. Wish everyone would do that, it would cut down on all these broken record threads.
  1. E39: Turning off the Check Brake Linings warning on the Instrument Cluster
    By NickG in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-08-2016, 09:46 PM
  2. Errasing the "Check brake linings" code
    By Darkness in forum 1995 - 2001 (E38)
    Last Post: 04-07-2004, 03:28 PM
  3. Check Brake Linings & Lowering ?'s
    By Magnum in forum 1995 - 2001 (E38)
    Last Post: 02-27-2004, 06:17 PM
  4. Check Brake Lining
    By toropoki in forum 1995 - 2001 (E38)
    Last Post: 10-04-2003, 02:06 AM
  5. Check brake linings, how do I reset??
    By jayb79 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-10-2003, 04:08 PM
