Results 1 to 14 of 14
Thread: e39 transfer case issues
    Oct 2015
    Oakville, Ontario, Canada
    '03 525iAT
    Or to be more precise, why has no one ever mentioned replacing the fluid in the transfer case ? 2003 525 wagon here, and the only discussion I ever see here, is the debate about whether or not to replace the "lifetime" transmission fluid.
    203,000 km on the vehicle, and I plan on keeping it for a long time. One shop makes no mention of the transfer case, and will do a tranny flush at half the cost of another shop, because they have this "machine" that will also remove the fluid from the torque converter. Interesting . . . (they should be charging more !).
    So I do have some drivability concerns. Upon light throttle application, there is a vibration that I feel through the gas pedal. The car shifts fine
    (auto), but it's sort of a throttle tip-in thing that causes this vibration and noise. I don't believe it has anything to do with the air/fuel. Fuel filter
    was done a month ago, and I've been experiencing this vibration for more than a few months.
    I mentioned the vibration issue to the shop that says "leave the tranny fluid alone, and it sounds like the transfer case could benefit from a flush."
    Almost as bad as an oil thread, I know
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Someone got confused with their Volvo wagon.
    No transfer case.
    And ignore the suggestion and change your trans fluid.
    Yonkers, NY and Argentina
    1998 528i 5speed Sport
    There is no AWD e39, so no transfer case.
    e30 325i, the mighty 4 door granma mobile....Gone
    e39 528i, 4 door sports tank
    San Jose, CA
    1997 BMW 540i 6 speed
    Is your wagon an "X" model? If not, there is no transfer case, as wagons ho intimates.
    There is no debate re changing the trans lube. BMW have relented, and now recommended a change at 100k mi.
    Beast not to use a pressure device, but rather, drain the sump 3X, drive it for 50 mi, and, before the last fill-up, change the filter.
    You may, or may not, get relief.
    Oct 2015
    '03 525iAT
    Yeah, this was not a trick question. I didn't say E60 or E61. Clearly I told him E39 wagon. Transfer case ? I was too embarrassed to say "I don't think my car has a transfer case." See how he handles that statement on Monday morning when I say hello again. He seems to think that flushing the transmission will cause all the sludge/carbon build up to break loose and cause problems. Says leave it alone.
    I subscribe more to the "if you're going to keep the car for a long time, then get it done."
    Hmmmmm.
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    Say no to the pressure flush
    Say yes to multiple drains/refills
    Apr 2016
    No to pressure flushing, and I doubt that they would have pentosin fluid loaded in the flush machine anyway.
    Drain and fill. Then run with the converter drain line (which goes to the trans cooler) rigged up to dump into a bucket. In gear or neutral as converter does not flow in park. Blow out cooler line with LOW pressure air. Determine which line is supply and cooler return when pan is off.
    When the 4qts from the pan is gone, or fluid runs clean, reassemble and fill. Better than drain and fill 2x's
    Oct 2015
    '03 525iAT
    Well, that's the problem. If I could do it myself, then I would. So no pressure flush. Wagons ho, your comments seem to match up with what most of the guys on the forum here are saying. Such a great knowledge base here. Thanks all !!
    Missouri
    '02 540i/6
    I'd find a more qualified shop.
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Forget the shop.
    Even if you cannot remove/replace the filter, just do a series of simple drain-and-fill. Though make sure you refill with the right transmission oil (I recommend Pentosin-ATF1-Syhthetic)....That is your best and cheapest solution for the longevity of your tranny.
    Oct 2015
    '03 525iAT
    Thanks Chedley. Since I sort of have access to a hoist, and I'm not a mechanic, maybe just get one of my shop mechs do do that procedure. Transfer case. WTH!!
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Maybe he means differential?
    Oct 2017
    Yes, he probably means the differential gear fluid.
    But that is even easier to drain and refill. It takes literally 15 minutes, if you can crawl under the rear of the car, with the right socket wrench.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by dohalloran View Post
    This guy's head could benefit from a flush. Don't go back there.
  1. How prevalent are 328d transfer case issues?
    By TNorth in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 10-09-2018, 07:35 PM
  2. Transfer Case Issue - Advice Needed!
    By Danielali in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 06-15-2017, 08:55 PM
  3. Help with transfer case and/or driveshaft issue
    By e24pilot in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-10-2016, 05:57 PM
  4. Need advice on Transfer Case leak issue
    By indyb in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-15-2012, 10:21 AM
  5. transfer case issues
    By dublediff in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 06-09-2010, 12:29 AM
