I got Exhaust Camshaft Sensor Bank 2 ( I believe its P0024) and I'm assuming the misfire codes for 5-8 go with it since they are new injectors and spark plugs. So I replaced the sensor and no luck. So, I swap intake and exhaust sensor cause they are the same. And still no luck. Am I missing something? Or should I start assuming it's the wire? I hope I'm missing something. PS I scanned the car. I have a high tech scanner that works with this car.
Forgot. 03 745Li E66
You've got larger issues than just a sensor. When a sensor is bad, or the wiring has a short or open, the DME will just use a substitute value and ignore the faulty sensor. If you've got misfires on 5-8, and cam sensor codes, more than likely the engine is out of time.
