I just picked up my Honda K24a2 from a 2007 TSX. Excited about this project, also have been in contact with KMiata for sourcing the adapter plate, flywheel and release bearing.
The other things that I will have to have made is the drive line. There is a well known place in my town that makes all sorts of drivelines so I am all good there...the next thing though, is the rear differential...Was told that the R200 differential is the way to go and has the right gearing and can hold a lot of power.
Been away from the forums because of schooling and work, will make sure to get on here as much as possible for everyone!
What axels will you use?
excited to see this build, this is dope, best of luck!
I think someone just finished this swap in Houston. May want to hit him up for info.
https://www.bimmerforums.com/forum/s...e-Swap-Non-BMW
