Results 1 to 6 of 6
Thread: Trying to diagnose a slow coolant leak 2001 325i
    Apr 2018
    Brooklyn, NY
    2001 BMW 325i Wagon
    2001 325i
    So this coolant leak has been around for quite a while, it's slow enough that I've just been putting up with it. I falsely diagnosed it as the classic expansion tank issue, replaced that, but that didn't solve it. I also recently replaced the water pump, but the leak was happening before that and the replacement didn't effect it (though the pump was definitely done).
    I think the leak is coming from the top of the radiator itself, which I'm guessing just means I have to replace the whole radiator, but I'm trying not to repeat my expansion tank mistake.
    So some pix - here's the most visible drip, but I've looked all around this drip and it seems pretty dry, I'm fairly certain it's coming from much further above:
    Here the left side of the radiator, just in front of the expansion tank. You can see coolant pooling on the three "lips" (for some reason this pic is rotating 90 degrees left when I post it)...
    And here's the top of the radiator (also just in front of the expansion tank) (again the forum is rotating this 90 degrees left bizarrely)
    Here's roughly where I think it's coming from, but not 100% sure...
    Close up:
    Any ideas (also any ideas why this images are getting rotated??)
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    The radiator is a 10 year replacement item, as the plastic to aluminum seal goes bad over time. Can you stretch it out to 15 or in you case 18 years, I wouldn't.
    I am assuming that you are using a pressure test to see the coolant coming out of those location, and you can get a replacement off of Amazon for around 150 bucks if you have a manual transmission.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    To add to Darin’s excellent advice, you need to overhaul the entire cooling system!! That means:
    - water pump (Saleri or Graf)
    - thermostat (Whaler)
    - upper and lower hoses (Continental)
    - serpentine belt (ditto)
    - idler and tensioner pulleys (INA)
    - radiator (Nissen or Behr)
    - expansion tank (Modine ONLY)
    - expansion tank bracket (?)
    - expansion tank cap* (?)
    - sensor in the lower radiator hose (likely VDO)
    - engine block coolant drain plug crush washer (dealer)
    - coolant (BMW ONLY)
    - distilled water.
    * Buy a 1.4 bar (1 bar = 14psi; 1.4 bar = ~20psi) cap instead of the 2 bar (28psi) cap that cane with the car. Why? This prevent the cooling system from getting too high. I’d did this in my old 330Ci and never regretted it. Buy the parts at FCPEuro as the vender provides a lifetime warranty on all parts.
    Do not piecemeal the replacement of cooling system parts. Just do it all at one time.
    Apr 2018
    Brooklyn, NY
    2001 BMW 325i Wagon
    So sounds like you think it's just the radiator and a replacement will solve it? I'm happy to replace it, just don't want to repeat my expansion task mistake if there's some other possible culprit I'm missing.
    Michigan
    2005 325Xi
    Just replace it. If it's original, it's past due anyhow. Many don't last much more than 10 years.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    dworthy's Avatar
    Nov 2010
    Yes, it is time for the radiator to be replaced. Have you replaced the surge tank carrier yet? Typically I do those at the same time the radiator is getting replaced.
    Also as a side note, if you are having a hard time getting the O-Rings to seal, use a little bit of dielectric grease on them.
    Darin
    Current:
    Past:
    M-Flight Member
  1. slow coolant leak - now I see white spots
    By hcoles in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-24-2008, 10:21 AM
  2. slow coolant leak
    By roarf in forum 1991 - 1999 (E36)
    Last Post: 12-22-2007, 10:12 PM
  3. Slow Coolant Leak (1 inch drop after 8 months)
    By archyx in forum 1991 - 1999 (E36)
    Last Post: 05-01-2007, 10:58 PM
  4. usual suspects with slow coolant leak?
    By Jason C SBB in forum 1992 - 1999 M3 (E36)
    Last Post: 04-18-2007, 01:57 AM
  5. Slow coolant leak
    By Alexi21 in forum 1996 - 2003 (E39)
    Last Post: 11-15-2006, 06:12 PM
