Results 1 to 7 of 7
Thread: BMW z3 convertible top issues
    Apr 2019
    Cuyahoga Falls
    BMW z3
    I have a 2000 bmw z3 and the convertible top works fine up and down but when I try to open it all the way it won’t lay correctly . Like the motor doesn’t want to pull it all the way into the slot. It’s about 4 inches up off the trunk and when I push it down it will go down into the slot but pop right back out . Please help , idk if it’s a bent frame or the hydraulic system
    Boiling Springs, PA
    '02 Z3 3.0i 5 speed
    New canvas on the frame? It may be tight and not 'broken in' yet.
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    it only takes a minute to unhook the hydraulics, then you can test it. it's behind the driver's seat.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    The hydraulic motor is in the trunk, left hand side. Remove the carpet and you'll see a "T" handle on the side of the unit. Give it a turn and you'll disable the hydraulics. Then see if the top sits down properly.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Apr 2019
    Cuyahoga Falls
    BMW z3
    I undid the hydraulic multiple times and it keeps wanting to pop right back up .
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Did you just turn the T handle, or did you unhook the cylinder?
    Sounds like the frame is bent
    Does it close to the windshield frame easily?
  1. bmw z3 convertible top boot tonneau cover
    By cocosultan in forum Z3,Z4,Z8 Classifieds
    Last Post: 09-20-2013, 01:16 PM
  2. bmw z3 convertible top boot tonneau cover - SOLD
    By cocosultan in forum Exterior Lighting & Body Parts
    Last Post: 08-30-2013, 09:17 PM
  3. 2001 bmw 325ci convertible top issue
    By speedybimmer12 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-20-2012, 07:37 PM
  4. 96-03 bmw z3 convertible top cover boot
    By mcgregg88 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-06-2012, 09:00 PM
  5. looking for a 1997 BMW Z3 CONVERTIBLE TOP BOOT / TONNEAU COVER
    By eware in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-20-2008, 12:46 PM
