Results 1 to 4 of 4
Thread: 1991 e30 318is lights problem
    Sep 2018
    Guernsey
    1991 bmw 318is
    Hey guys recently got a left hand drive 318is been a pain. So reverse lights do not work at all. Right rear brakelight/tail light doesnt work and front headlight sidelight does not work also there doesnt seem to be any lights behind the speedo i not sure if that's normal and heater switches have no lights i have tried turning the knob but that doesnt do anything at all. I checked the fuse i thought it was and aeriel went up lol um but all the fuses seem okay swapped bulbs and still dead on exterior lights anyone have any info on prefacelift 318is fuses or lights thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E30 forum
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    for the cluster, check the brass nuts behind the two smaller gauges.
    for the exterior, I bet you have a bad ground somewhere.
    the hvac panel is pretty normal to not work. there are two small bulbs behind the panel, if I remember right. you can undo the screws at the bottom of the panel and pull it out a bit but there is a cable that will hold it back once you get to far.
    No e30s again.
    Joliet,IL
    87 325is 96 GMC Suburban
    Possibly screws behind/ after pulling off the control knobs?
  1. 1991 e30 318is handbrake problem
    By Rob.star93 in forum 1983 - 1991 (E30)
    Last Post: 03-01-2019, 11:24 AM
  2. 1991 e30 318i oil leak and other problems.
    By crap60148 in forum 1983 - 1991 (E30)
    Last Post: 06-13-2013, 03:54 PM
  3. E30 FS: 1991 E30 318iS - 5 Speed - SoCal
    By MR 325 in forum 3 series & Z Series
    Last Post: 01-29-2010, 10:52 PM
  4. E30 1991 E30 318is
    By 2many02s in forum E30 Parts Classifieds
    Last Post: 08-07-2009, 03:54 PM
  5. 1991 E30 318i heater problem HELP
    By pdxh20 in forum 1983 - 1991 (E30)
    Last Post: 12-10-2007, 10:56 PM
