Results 1 to 5 of 5
Thread: Loss of brake boost
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    Loss of brake boost
    I am autocrossing an 04 M3. The brake system is healthy, fresh Ferodo pads, flushed systems, etc. ABS works as designed. BUT, after trail braking into some corners and flat footing the gas to the next element, there is a pattern of lack (or non-existent) brake boost. ................ Anyone else had this problem? Any known solutions? In daily driving there are no problems.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    You can check the 1-way valve to ensure it isn't clogged, or the lines going to the booster. The brake booster uses engine vacuum, so if you are always at a high RPM, there is a chance it doesn't have enough time to build before you hit the brakes again.
    Lastly would be a bad booster, does it hold pressure, or do you hear a hissing sound when the car is turned off?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2010
    KC, Mo
    No "hissing".
    As far as I can tell, the 1-way valve is good. But, I plan on changing it anyway.
    When I roll the car off of my trailer, with the engine off there is power assist --- ONCE !!
    I spoke with Active Autowerke (source of all my tunes), and Karl (senior tuner and human BMW encyclopedia) says that this is a common issue. My co-driver and I may have to lift (a bit) before some turns to generate vacuum.
    dworthy's Avatar
    Nov 2010
    You should get 2-3 pumps off the brake pedal before it losses all assist. So check this: After you drive the car, let is sit overnight. If the pressure bleeds off by morning, I would do the check valve first. If that doesn't fix it, get it smoke/pressure tested.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2010
    KC, Mo
    Check valve is already coming.
  1. Brake boost leak
    By brandkop in forum 1999 - 2006 (E46)
    Last Post: 11-01-2008, 01:05 AM
  2. DSC Light and Loss of Braking Power
    By GreekDriver in forum 1999 - 2006 (E46)
    Last Post: 10-27-2008, 07:02 PM
  3. Loss of brakes and steering on 540i. Any advice please?
    By swiftpete in forum 1996 - 2003 (E39)
    Last Post: 01-24-2008, 02:22 PM
  4. poor brake boost with the m50 swap
    By 325bob in forum Engine Conversions
    Last Post: 12-13-2007, 01:11 AM
  5. Brake-Boosting?
    By 328DTM in forum Forced Induction
    Last Post: 02-12-2003, 01:25 AM
