Results 1 to 5 of 5
Thread: erratic temperatures...or erratic guage?
    Feb 2012
    Southern Ontario
    93 850Ci, 2012 X5 35d
    Pulling my hair out trying to diagnose an issue which seems to defy logic....
    Temp gauge swings rapidly from 12 o clock to one bar before red...and back to 11 o clock, no heat at defrost,
    Thought maybe thermostat, but if so it is opening and closing at will, not stuck,
    thought fan, but it goes up and down whether at highway speeds or not...
    thinking temperature switch? Is there any correlation with the gauge, and the valve that cycles to provide flow for the interior heat? I don't hear the usual clicking from the flow valve for lack of a better term, so maybe its not opening? could this somehow manifest itself as the swinging gauge?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    If you have no cabin heat you are probably short of coolant - parts the cabin heater (such as the pipework) is the highest point of the cooling system so usually suffers first. The cabin heater is not affected by the thermostat (unless the complete system fails to reach temperature) and is in a separate loop.
    All explained here:
    My BMW Repair YouTube Channel
    Feb 2012
    Southern Ontario
    You were correct...I put the front end up about 50cm, it took almost two litres of coolant, appears to be operating normally now...thx
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by Sundancer View Post
    Where'd the missing coolant go?
    1993 850Ci.....18 years & 165,000 miles and counting!
    Feb 2012
    Southern Ontario
    That...
    is a very good question...
    Investigation to follow....
  1. Another cooling thread, erratic temperature gauge, 2000 Z3 2.8 Coupe
    By jpapa in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-09-2017, 09:11 PM
  2. Erratic Temperature Sensor - Erratic Spiking Idle
    By cazten in forum 1999 - 2006 (E46)
    Last Post: 03-02-2016, 08:34 AM
  3. Erratic tachometer/dead mpg guage
    By Brianl289 in forum 1983 - 1991 (E30)
    Last Post: 08-07-2012, 12:15 AM
  4. Erratic temperature gauge
    By paanta in forum 1988 - 1996 (E34)
    Last Post: 05-23-2010, 01:07 AM
  5. climate control - heater erratic temperature
    By donle99 in forum 1995 - 2001 (E38)
    Last Post: 01-23-2004, 05:10 PM
