RM European Auto Parts
Results 1 to 4 of 4
Thread: Various electronic problems
    Apr 2019
    Adelaide Australia
    2008 x5 E70 3.0sd
    Hi Guy's,
    New member here, Ive recently taken ownership of a 2008 X5 E70 3.0sd and have a few gremlins I'd like to sort out.
    Hoping to find some answers for the following problems:
    1. Reverse camera not working but in it's place the navigation map comes up , the PDC is functioning.
    2. Bluetooth does not seem to be working (My phone doesn't detect anything)
    3. Voice control doesn't hear me, but I can hear the beep and it tell me it doesn't understand me.
    4. The auxiliary port (3.5mm jack) in the armrest doesn't seem to work although its available in the entertainment hub.
    I have replaced the media module in the trunk as it showed water damage, but that didn't seem to change anything.
    Could it be another module that controls all or some of these features.
    The radio and CD work as does Nav,
    Ive run a scan with Carly and these are the results:
    Instrument cluster / Kombiinstrument
    Fault Code: 00A554
    Fault Explanation: :ALIVE error Phone / live phone
    Car Communication Computer CCC
    Fault Code: 00E18F
    Fault Explanation: :Central Registry does not match the target
    configuration (Error Registry New).
    Fault Code: 00E18D
    Fault Explanation: :Awakening device has three times
    unsuccessfully, the network tries to awaken (Error WakeUp Failed) /
    Awakening device has unsuccessfully tried to wake the network times.
    3 (Error WakeUp Failed).
    Junction Box Passenger / Beifahrer
    Fault Code: 00A737
    Fault Explanation: :K-CAN MESSAGE (ID2BF, VALVE): FAILURE BY
    TIMEOUT
    I don't know about you guys but, I'm a little puzzled to say the least.
    If someone understands any of these faults, please share.
    Thanks in advance
    Chuck
    Apr 2019
    Adelaide Australia
    2008 x5 E70 3.0sd
    This must be a tough question, many looks but no replies.
    Nov 2016
    Charlotte, NC
    '02 540i-6, '97 540i-6
    First, I'd use the search function here to see if there are similar threads where this has been addressed for that or a similar model.
    I also suggest posting a new thread with these same questions on the section specifically for that model. (Many users just scan the threads for their cars.)
    Jan 2016
    Ca
    2001 525it
    Certainly it could be the ccc since it is the main device that deals with comms, climate control etc but it would be nice to get a good diagnostic before replacing it or is some thing interrupting the can system. The sos system could mess with things and you could remove it from the system with the optical loop, but there would be a warning about it.
  1. E46 M3 Electronics Problem!!!!!
    By HiRide in forum 2001 - 2006 M3 (E46)
    Last Post: 10-09-2011, 02:15 AM
  2. Various Electronic Problems
    By AudioClutch in forum 1991 - 1999 (E36)
    Last Post: 02-14-2009, 04:38 PM
  3. E39 Electronic problem, help please?
    By JuanPac0 in forum 1996 - 2003 (E39)
    Last Post: 01-24-2007, 12:43 PM
  4. idle/electronics? problem...
    By ianv in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-15-2005, 02:48 PM
  5. weird electronic problem
    By keke1985 in forum 1991 - 1999 (E36)
    Last Post: 04-08-2005, 03:39 PM
