Hi Guy's,
New member here, Ive recently taken ownership of a 2008 X5 E70 3.0sd and have a few gremlins I'd like to sort out.
Hoping to find some answers for the following problems:
1. Reverse camera not working but in it's place the navigation map comes up , the PDC is functioning.
2. Bluetooth does not seem to be working (My phone doesn't detect anything)
3. Voice control doesn't hear me, but I can hear the beep and it tell me it doesn't understand me.
4. The auxiliary port (3.5mm jack) in the armrest doesn't seem to work although its available in the entertainment hub.
I have replaced the media module in the trunk as it showed water damage, but that didn't seem to change anything.
Could it be another module that controls all or some of these features.
The radio and CD work as does Nav,
Ive run a scan with Carly and these are the results:
Instrument cluster / Kombiinstrument
Fault Code: 00A554
Fault Explanation: :ALIVE error Phone / live phone
Car Communication Computer CCC
Fault Code: 00E18F
Fault Explanation: :Central Registry does not match the target
configuration (Error Registry New).
Fault Code: 00E18D
Fault Explanation: :Awakening device has three times
unsuccessfully, the network tries to awaken (Error WakeUp Failed) /
Awakening device has unsuccessfully tried to wake the network times.
3 (Error WakeUp Failed).
Junction Box Passenger / Beifahrer
Fault Code: 00A737
Fault Explanation: :K-CAN MESSAGE (ID2BF, VALVE): FAILURE BY
TIMEOUT
I don't know about you guys but, I'm a little puzzled to say the least.
If someone understands any of these faults, please share.
Thanks in advance
Chuck
This must be a tough question, many looks but no replies.
First, I'd use the search function here to see if there are similar threads where this has been addressed for that or a similar model.
I also suggest posting a new thread with these same questions on the section specifically for that model. (Many users just scan the threads for their cars.)
Certainly it could be the ccc since it is the main device that deals with comms, climate control etc but it would be nice to get a good diagnostic before replacing it or is some thing interrupting the can system. The sos system could mess with things and you could remove it from the system with the optical loop, but there would be a warning about it.
