Has anyone used the cheap tool sets available on amazon or it it smarter to pay extra from one of the supporting vendors?
See my sig.
The quality of the tool really doesn't matter. You could use a piece of flat bar and c-clamps if you wanted to. The cams just need to be flat on the back relative to the head and parallel with each other.
I can rent you the actual tools if you'd like as well, but really they are $40 to buy. Just grab a set:
https://www.ebay.com/itm/BMW-M54-M52....c100677.m4598
-Dr. Seuss
Similar experience to Hova. I used this sprocket tool (similar ones are listed), and this camshaft locking set that I picked up from eBay. Everything fit just fine. Hova's link looks good and it comes with the sprocket tool already.
Feel free to ask about my car:
TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
M50 Manifold | ASC Delete | Dinan BBTB | Fan Delete | Power Pulleys | Dinan CAI | S54 Oil Cooler
Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | AKG Chassis Mount Shifter
SS Long Tubes | SS Race Exhaust | LTW Replica Wing | MM Underpanel | CF Sunroof Delete
OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation | Turtle Labs Door Panels
And Really Old Paint
Check out my YouTube channel for more DIY's and videos about my E36 M3
I bought mine from eBay as well. Baum Tools.
They've been used multiple times, no issues and definitely saved me a lot of money by being able to service the VANOS at home.
You should consider getting the VANOS air tester as well if you have an air compressor. It's the right way to do the job.
https://www.ebay.com/itm/BMW-Vanos-T...-/121512914395
https://www.youtube.com/watch?v=angrrw9TaRc
If you don't have an air compressor to do the test, you could go just use the VANOS wrench and measure the distance, but again it's not the proper way to test and assemble it.
-Dr. Seuss
FEEDBACK THREAD
00-03 Nissan Maxima HID Retrofit
6th gen AV6 FX35 Retrofit
Chassis and Suspension
2011 Space Grey E82 N55 DCT
2000 Sunlit Sand Maxima SE 5Spd.
1997 Arctic Silver E36 M3/4/5.
1997 Techno Violet E36 M3 Coupe 5Spd (SOLD).
I bought the $45 set of timing tools from Amazon seller Aurelio Tech. They ended up working correctly but there was one issue with the cam blocks where the intake side block was not level fore to aft.
While the block was actually sitting flush on the head, the forward edge appeared to be not contacting the head. When I placed the exhaust side block on the intake cam, without moving anything else, the block was flat against the head. Found that a feeler gauge would only slide 1/3 of the way towards the rear where the timing block was then in contact with the head. Checking it against a different flat surface and I could see the forward edge of the block was not machined flat like the rest of it.
Once I knew that I was less worried but at first it confused the heck out of me.
11 128i Space Gray slicktop
13 WK2 Deep Cherry
Just a warning that the set of eBay tools that I got were machined horribly and one side was loose enough for a few degrees of play while I had to file the other one down because it didn't fit over the cam square.
