Results 1 to 7 of 7
Thread: E32 Installing Memory Power Seats Problem - RETROFIT HELP
    Apr 2019
    Chile
    BMW 730 E32 1987
    Unhappy E32 Installing Memory Power Seats Problem - RETROFIT HELP
    Hello!
    I just bought a pair of BMW E32 memory power seat from a 1989 BMW 735i E32, to install them in my BMW E32 730i 1987 (VIN 2180019) who came from factory with manual seated heats.
    When I bought the memory seats, I made sure that they came with the MEMORY MODULE (under the driver's seat) and the memory harness (that connect the memory to the car harness).
    So I readed all the topics about this retrofit on the internet and found out that the major problem is connect the driverīs seat and make it work, just because the stupid memory module have his own harness, so if you donīt buy the memory harness you are partially screwed (I said partially, because some genius on this forum have made it work even without the harness doing some mods and grounding it and bla bla).
    Until this point everything was running fine because I had bought the memory harness too and I was thinking: "great this will be just a plug and play business". OK! So I connected the co-pilot seat and it was really plug play, everything worked fine. But, as everything related with this brand is always a problem, all of this couldnīt be so easy, it was everything running so perfect to be truth: I connected the driverīs seat with the memory module to the wiring harness (which fitted perfectly on memory module, and with the carīs harness) but I had no luck, it didnīt worked. Nothing moved, and there is no light on memory button, nothing. GOD! COME ON! WHY ME! haha
    So I started to search info about this and had no luck again, there is no much info on the web.
    Then I readed that exist two types of this memory module: EARLY TYPE and LATE TYPE. I donīt know what year determine one or another type (again there is a lack of info ), but some guy in this forum called NIRVANA19 said that EARLY TYPE modules wonīt work after connect them, if they donīt receive input signals from memory mirrors or memory steering column and there is a trick to make it work (but he didnīt explained how to do it). So I'm suspecting this on my situation, because all of the DIY here on BimmerForums, about this retrofit are made with 1994/1995 MEMORY POWER SEATS. DOES SOMEONE KNOW SOMETHING ABOUT THIS? Please somebody help me
    SHOGUN PLEASE HELP!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I am not the expert for this, can only give you a link to the training manual http://www.e38.org/e32/BMW_pdfs/smm.pdf
    Maybe ask demetk from the E34 forum to read this thread, he has some experience with that.
    Apr 2019
    Chile
    BMW 730 E32 1987
    Quote Originally Posted by shogun View Post
    thank you! i will!
    Apr 2019
    Chile
    BMW 730 E32 1987
    up, some help please
    Jan 2005
    Japan
    Demet once posted this on Bimmerboard E23 forum, when he installed E32 seats http://www.bimmerboard.com/forums/posts/798596
    the SMM module under the seat was the same till 03/1993: Seat and mirror memory control unit <>03/1993 61351388561
    61351388561 Seat and mirror memory control unit
    From:12/01/1989 To:- Weight: 0.830 kg Price: $1780.49
    Superseded by: 61358356510 (03/01/1993 — ), nonexchangeable retrospectively
    Supersedes: 61311378662 (06/01/1986 — 04/25/1990)
    Part 61351388561 was found on the following vehicles:
    5' E34   (03/1987 — 12/1996)
    7' E32   (10/1985 — 04/1994)
    8' E31   (07/1989 — 10/1996)
    Apr 2019
    Chile
    BMW 730 E32 1987
    thanks, it is some good info. I still need info about EARLY and LATE models and if only LATE model works retroffiting it on a car without memory mirrors/steering column input signal to the module.
    Apr 2019
    Chile
    BMW 730 E32 1987
    Look at this thread http://bimmerboard.com/forums/posts/744555
    At the end, some user called NIRVANA19 wrote that some EARLY modules wonīt work without input signal form memory mirrors or memory steering column.
  1. 93 E36 Power Seat Problem?? Please help
    By krazychikka in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-10-2009, 04:17 AM
  2. Help!!!!!power Seats Problem
    By Mperformance in forum 1991 - 1999 (E36)
    Last Post: 04-04-2007, 04:43 PM
  3. Replies: 2
    Last Post: 12-13-2006, 08:00 PM
  4. Power seat problems *pls help*
    By psychocandy in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2003, 01:32 AM
  5. Power Seat Problem, tell me why
    By cleoent in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-19-2002, 01:18 PM
