Results 1 to 8 of 8
Thread: E32 EDC III - is there a problem or its just like that
    Nov 2016
    Burgas city,Bulgaria
    e34 525tds touring 1992
    E32 EDC III - is there a problem or its just like that . Hello I have 730i e32 with edc III ,the case its this . When I turn on the sport regime it becomes hard the suspension (wich is ok ,must be like that ) but when I switch on comfort mode the car starts to be I think way too much "soft"like in an old mercedes with the spring seats (w123 )It feels too soft only IN FRONT ,in the back its I think normal . Is there any problem and in which parts to look for it shocks , hydraulic spheres ,modules or sensores?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I do not have EDC III on my car, but I have driven some E32 750 with EDCIII and I had the same feeling, in sports very hard, in comfort for maybe too soft, well, it is comfort setting then.
    In any case that shows that your system works, in case the control module is defective it always automatically goes to sports setting.
    Once we did a oil change in the front shocks on such a system on an Alpina B12, that helped a bit with new oil, http://e32b12.blogspot.com/search/label/Suspension
    Mar 2013
    Green Bay, WI
    1992 750il / 1991 560 SE
    I was going to say, its probably time to refresh the front shocks. The rears are constantly being circulated with new fluid so unless they have a physical failure, they will always perform as new. For the rears, the biggest part that can fail is the accumulators. But the fronts are a sealed system. So the oil can go bad or the seals can fail causing oil loss.
    ______________________________
    1992 750iL
    Loveland, Colorado USA
    1993 740i
    Mine are similar. I'm going to try replacing the oil in the fronts with shock oil that's about 20% more viscous (based on some data Shogun published) than the stock Pentosin, which I hope will bring the damping more in line with the H&R sport springs I have on the car.
    '93 740i - Mine
    '13 Range Rover Sport - Hers
    '08 Land Rover LR2 - Hers
    '96 328i - Son's
    '97 328ic - Daughter's
    '87 944 Turbo - Mistress
    '74 Alfa Romeo Spider - Italian Mistress
    Northern Colorado, USA
    USA
    e34 540ia/e32 740il
    Quote Originally Posted by gregeast View Post
    You have EDC on a 740?? Is that factory? I didn't even know that was an option.
    Jan 2005
    Japan
    EDC I and EDC III was always an optional extra. EDC II was never used on E32. EDC II was available for the E30 M3.
    EDCI is the more simple version for the first built years, EDCIII is much more complicated, also from design of the shocks.
    The most expensive EDC III shocks are the ones for the rear combining EDCIII and SLS/LAD for the iL version.
    EDCIII German list price accdg to a 1993 price list for optional extra, option 223 EURO 1383,04 = approx 1400 $ back in 1993. Available there for 730 M30, 730 M60, 740i, 740iL, 750i, 750iL, for the 750iL Highline version it was included in option package 448 for roughly $10000
    Highline option: Große Tunnel-/Fondkonsole mit Naturleder Buffalo bezogen. Individuelles Fond-Klima-System und Kühlbox zwischen den Hintersitzkissen (dadurch Begrenzung auf zwei Sitzplätze im Fond). Aufklappbare Mittelarmlehne hinten mit Edelholzverblendung am Deckel innen, integrierter Radio-/CD-/Kassetten-Fernbedienung, Bedienteil für elektrische Beifahrersitzverstellung und Bedienschalter für elektrisches Heckscheibenrollo. Schmale Ablagetische an Fahrer- und Beifahrerlehnenrückseite, indirekt beleuchtet, mit Edelholzverblendung Nußbaumwurzel hochglänzend, sowie Lehnentaschen. Fußstützen im Fond, abklappbar. Ohne Mittelarmlehne vorn (räumliche Überschneidung mit Fondkonsole); 2ter Generator 32A, zweite Batterie 25 Ah im Kofferraum.
    Enthaltene Sonderausstattungen: Elektronische Dämpfer Controll III (EDC III) (Schl.-Nr. 223), Sonnenschutzrollo für Heckscheibe mit elektrischer Betätigung sowie für beide hinteren Seitenscheiben mechanisch (Schl.-Nr. 416), Velours-Fußmatten vorn und hinten (Schl.-Nr. 423), Innenspiegel automatisch abblendend (Schl.-Nr. 431), Lordosenstütze für Fahrer, elektrisch einstellbar (Schl.-Nr. 488), Sitzheizung für Fahrer und Beifahrer (Schl.-Nr. 494), Sitzheizung für Fondsitze (Schl.-Nr. 496), Park Distance Control (PDC) (Schl.-Nr. 505), Automatische Umluft-Control (AUC) (Schl.-Nr. 528), BMW Bavaria C Professional RDS (Schl.-Nr. 662), mit BMW Bavaria CD 6 Selektion (Schl.-Nr. 672), Hifi-Lautsprechersystem (Schl.-Nr. 676), Kassettenhalterung (Schl.-Nr. 690), Vollederausstattung in Naturleder Buffalo in anthrazit.
    Nicht in Verbindung mit Skisack (Schl.-Nr. 464) und BMW Sportsitz für Fahrer und Beifahrer (Schl.-Nr. 481)
    https://www.7-forum.com/modelle/e32/...usstattung.php
    USA
    e34 540ia/e32 740il
    ^ Great info shogun! It always fascinated me that BMW was able to combine LAD and EDC in the rear shocks. I have a very good understanding of how LAD works (thanks to the info/pics/diagrams you've posted over the years), but not EDC since I've never had a car equipped with it. One of these days I'll read up on it.
    1993 740i
    Quote Originally Posted by m60power View Post
    Standard equipment on 740i's, as far as I know.
    '93 740i - Mine
    '96 328i - Son's
  1. E32 Rear Set of Good Non Leaking E32 EDC shocks Available!
    By dragon850 in forum Suspensions, Springs & Shocks
    Last Post: 05-09-2014, 05:57 PM
  2. EDC III problem - electrical gurus needed!
    By whiteghost1 in forum 1988 - 1994 (E32)
    Last Post: 05-02-2012, 02:23 AM
  3. EDC III electronic damping control TSB
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 07-08-2009, 10:26 PM
  4. e32 EDC/LAD conversion
    By wessel in forum 1988 - 1994 (E32)
    Last Post: 11-26-2004, 07:49 AM
  5. EDC III M5 on 540i 1995/06 6 speed manual?
    By Renevan in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-28-2004, 11:22 AM
