Results 1 to 7 of 7
Thread: 1988 BMW 735i auto transmission issue
    Apr 2019
    Michigan
    1988 BMW 735i
    Exclamation 1988 BMW 735i auto transmission issue
    Could use some help I got a 1988 BMW 735i bought it about 2 year back and havent been able to drive it for more then half that time. I was driving it one night down the highway and hit something like a tire retread from a semi or something and the transmission started acting up like it was slipping lasted all of 2 days then lost drive will still go in reverse but i dont know if it needs an all new trans or something to do with the rear end but in the dash after it runs for a minute it says "trans program." And the D,E,S settings dissapear is it something to do with that or something else I just want to get her rolling again. Any info will be greatly appreciated.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Post moved to E32 forum from Forum Software Questions & Suggestions.
    In case you hit something on the street, first of all check if the trans cooler and the trans cooler lines are not damaged. Is there ATF under the car? Check the fluid level of the transmission, ino on that here under DIY https://www.bimmerforums.com/forum/f...-and-DIY-Fixes
    Oldham UK
    '00 330i Sprt '92 525i
    When you get 'transprog' in check control, it is normal for the mode and gear selection to disappear from the cluster. What you are normally left with is a high forward gear plus reverse. You will not even get that if all the ATF has drained away. Perhaps start by following Shogun's instruction and confirm if you found ATF under the car? And if you didn't, confirm it has some in the trans? It would also be useful if you had a look at the shift cable adjustment. What you think you are telling the trans to do with the shift lever may not be translated correctly at the other end due to damage
    Apr 2019
    Michigan
    1988 BMW 735i
    What is ATF sorry not good with short hand and I checked the trans fluid and it's still full and I dont see any leaks at all and where do I find the shift cable adjustment?
    Oldham UK
    ATF= automatic transmission fluid. Great that you don't see any leaks and you checked level as per procedure. Shift cable adjustment is on (your) driver's side of the trans. About as simple as a bicycle brake cable to adjust but worth checking in case of impact damage
    Apr 2019
    Michigan
    1988 BMW 735i
    Oh ok I'll take a look at that when I get home and see if it needs adjustments. Thank you .
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Another thing worth checking is if the gear selector switch assembly or the shifter cable was damaged by whatever you hit as they are exposed under the car - more information regarding the switch here:
    https://www.meeknet.co.uk/e31/timms_...e_problems.htm
    My BMW Repair YouTube Channel
  1. 735i auto transmission issues
    By surewriting in forum 1988 - 1994 (E32)
    Last Post: 05-07-2017, 06:44 PM
  2. Replies: 2
    Last Post: 08-20-2014, 06:21 PM
  3. 1994 BMW 325IS Auto Transmission Issue READ PLEASE!
    By 1SickEuro in forum 1991 - 1999 (E36)
    Last Post: 03-04-2013, 08:35 PM
  4. 1988 BMW 735i transmission (no Reverse)
    By jfarmer64 in forum 1988 - 1994 (E32)
    Last Post: 06-14-2011, 01:01 AM
  5. Weird electrical issues (1988 BMW 735i)
    By SeanH in forum 1988 - 1994 (E32)
    Last Post: 09-07-2009, 09:13 AM
