RM European Auto Parts
Results 1 to 7 of 7
Thread: Rear suspension bent
    Apr 2019
    Czech republic
    BMW E46 325i
    Hi,
    I had the alignment of my E46 325i done, and the front was perfect, but they couldn't get the rear done properly, they just ran out of space to move the bolt that goes in the chasis. When I drive the steering wheel is a bit to the right.
    What are the most probable bent suspension parts? Could I find them just by simply measuring them with tape measure?
    Thanks for all hints.
    NW suburban Chicago
    hiss by my window
    Doesn't need to be bent. Worn out bushings can also make it impossible to properly align. If your only complaint is the steering wheel not straight that is easily corrected by adjusting the tie rods.
    Maybe time for a different alignment shop.
    Apr 2019
    Czech republic
    BMW E46 325i
    Quote Originally Posted by ross1 View Post
    Thanks for the reply.
    It could be possible that I have some worn out bushings, but when I first got the car rear wheels were visibly turned to the right. That's why I think that there's something bent. The car axis is few minutes off centre...
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Can you post the alignment shop’s printout if your car’s alignment specs?
    You definitely need a new alignment shop.
    If there's bent components, a competent shop will tell you what parts are bent, and give you an estimate to repair it. As well as your steering wheel would be straight while driving straight.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Nutkick View Post
    BOTH rear wheels pointing right? More likely a bent car than suspension components. If that car hasn't been smacked hard in the side I'd suspect the sub-frame mounting bushings are done.
    Michigan
    2005 325Xi
    If the car can't be brought into spec, it's better for the measurements to be equal on both sides, than to have one side in-spec with the other side maxed, but out of spec.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
  1. I AM IN NEED OF HELP REALLY BAD! Rear Suspension Components Bent
    By SteelGray3 in forum Middle Atlantic - US
    Last Post: 11-21-2009, 12:55 AM
  2. Possible reason for my rear wheel suspension bent inward?
    By Solidhead in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-29-2005, 02:06 PM
  3. noisy rear suspension
    By daytonflyer53 in forum 1991 - 1999 (E36)
    Last Post: 09-16-2001, 11:36 PM
  4. Worn rear suspension ??????
    By Miles-uk in forum 1991 - 1999 (E36)
    Last Post: 04-18-2001, 03:16 AM
  5. HELP! squeaky steering and rear suspension noise
    By BimmerXTC in forum 1991 - 1999 (E36)
    Last Post: 04-02-2001, 05:12 AM
