Hi I have a 1990 535i, that has developed a jerking/bucking while driving. The car idles great and there is no hesitation when I rev it up in driveway. However, when I start driving the car jerks around 2k rpm. Sometimes, there is also a popping noise from the exhaust. When I floor it, the car goes smooth, but when I gradually bring it to 2k rpm the car bucks back and forth. New cps, dizzy cap and rotor, spark plugs and wires, fuel pump and filter etc.
Any ideas?
"popping" from the exhaust would usually have me pointing at the ignition(is coil strong & gaps correct?) but seeing that you've addressed that I'd suspect a lean miss under load, vacuum leak.
The problem randomly stopped...interesting
problem is intermittent... it is specifically at 2k-2.5k rpm when foot is steady on throttle
Okay, have you checked the ignition system yet?
Do you have a shop manual to tell the values you are looking for?
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Suspect a throttle position sensor issue. Look up resistance values for yours and check that 1. they're correct, and 2. they change smoothly through the throttle's range.
