Results 1 to 6 of 6
Thread: m30 engine problem
    Aug 2016
    NJ
    1990 535i
    m30 engine problem
    Hi I have a 1990 535i, that has developed a jerking/bucking while driving. The car idles great and there is no hesitation when I rev it up in driveway. However, when I start driving the car jerks around 2k rpm. Sometimes, there is also a popping noise from the exhaust. When I floor it, the car goes smooth, but when I gradually bring it to 2k rpm the car bucks back and forth. New cps, dizzy cap and rotor, spark plugs and wires, fuel pump and filter etc.
    Any ideas?
    NW suburban Chicago
    hiss by my window
    "popping" from the exhaust would usually have me pointing at the ignition(is coil strong & gaps correct?) but seeing that you've addressed that I'd suspect a lean miss under load, vacuum leak.
    Aug 2016
    NJ
    1990 535i
    The problem randomly stopped...interesting
    Aug 2016
    NJ
    1990 535i
    problem is intermittent... it is specifically at 2k-2.5k rpm when foot is steady on throttle
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Okay, have you checked the ignition system yet?
    Do you have a shop manual to tell the values you are looking for?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
  1. Repost From M3 Forum - Engine Problems
    By ///MikeL in forum 1991 - 1999 (E36)
    Last Post: 12-10-2001, 11:57 AM
  2. Engine Problems - Need advice
    By ///MikeL in forum 1992 - 1999 M3 (E36)
    Last Post: 12-06-2001, 05:12 PM
  3. Major engine problems!! Please help.
    By Scott S in forum 1991 - 1999 (E36)
    Last Post: 09-25-2001, 06:55 AM
  4. Wierd Engine problems. ??
    By joey328is in forum 1991 - 1999 (E36)
    Last Post: 07-15-2001, 06:29 PM
  5. Possible engine problem?
    By Pic in forum 1992 - 1999 M3 (E36)
    Last Post: 05-31-2001, 01:26 AM
