SOLD
As the title states, I have a TC Kline DA setup for sale. Includes the following:
Front and rear koni DA shocks
TCK camber plates
450/550 f/r springs
Ground Control height adjusters in the rear
TCK rear shock mounts
Why so cheap you ask? I recommend a rebuild all around. The rears are definitely blown and in need of a rebuild. When compressed it takes quite a while for them to push back out to full extension. I assume the fronts are in similar condition but they are harder to test without removing the springs. There are a few shops around the country that rebuild konis (you can rebuild to any spec) for $150-$200 per corner. My price is shipped to the shop of your choice or to you.
Tentatively sold. Thanks for the interest.
if this falls through, let me know. I live 10 min or less from TC kline HQ. thanks
These are sold, thanks.
TCK Koni are not gas pressurized like Bilsteins which is why they don't return. A damper that is blown will have little or no resistance to movement. Those shock may not be blown
