Results 1 to 15 of 15
Thread: Needs to return to my original vin after dme change
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I recently changed my dme because it’s failed ( harness short ) , change it with a suit of dme ews and key , the car works but it has new codes of ventilation valve of tank and another one ( code 1,2 ) I think my car dose not have these sensors .
    Also I have decrease eco
    Can I reprogram the new dme to have the old vin ?
    I hear about changing a chip ( putting the old dme chip to the new one) any idea?
    lA, ca, lA
    BLK 01 sp, 20 Trail Boss
    You can't do it but Dima (Dudmd ) who you can locate on this website or facebook does it...............
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    You could try and code that stuff out but there would be a big learning curve and a risk of killing the new DME. Dima would be the safe bet but you would have to give him specifics of what you want coded out.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    Quote Originally Posted by haydar alameen View Post
    Curious what were your symptoms before you changed DME?
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
    Feb 2009
    KC North, MO, USA
    1996 740iL
    IL
    2000 740i sport
    No need for Dima here. If you already replaced the DME EWS and key and its running, you most likely used a DME from a 540 or an x5 and you can just flash it with the correct 740 software using WinKFP. If you want to put the original ews and key back into the picture then you will need to contact Dima to assist with virginizing the replacement DME...
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Quote Originally Posted by haynes740 View Post
    Are you mean why I change the dme ?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Quote Originally Posted by purplecty View Post
    If I get the new dme vin and it belong to 7 series but Japanese version , is that problem ?
    IL
    2000 740i sport
    Possibly because it has Japanese software on it...
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I mean is that problem with performance , eco ? It gave error code 1 ,2 I think for evaporator system , I do not have it in my car
    IL
    2000 740i sport
    Probably mainly for the emissions differences in your region...
    Mar 2014
    Iraq
    1998 BMW e38 740i
    The ecu is from USA market feb 1998 , my original ecu is euro oct 1997
    IL
    2000 740i sport
    So its not japan?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    So its not japan?
    No , the seller told me previously that his parts mainly from used Japanese cars , it’s also 7 series not 5 or x5
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I have 6 extra errors ( 4 for post cat sensors and heaters ) and 2 ( code 1 ,2 )
  1. S50B30 Engine is not running after DME change
    By dmanetsgruber in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-22-2015, 04:24 AM
  2. S50B30 Engine is not running after DME change
    By dmanetsgruber in forum 1994 - 1999 Euro M3 (E36)
  3. need input on value of original rims
    By DANKeuro in forum 2002
    Last Post: 11-25-2006, 10:33 PM
  4. need a summer internship [posted originally in off topic area]
    By m3avrck in forum Middle Atlantic - US
    Last Post: 04-22-2003, 01:06 PM
