Results 1 to 18 of 18
Thread: UUC EVO3 shifter positioning
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    I had UUC SSK installed without DSSR in my '96 ZF converted car and the shifter is slightly more forward than stock - I am looking to fix this. Will adding DSSR place it back into original position or should I get adjustable DSSR to compensate?
    Thanks.
    http://www.hardmotorsport.com/cae-ds...tor-joint-bmw/
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    The DSSR alone won’t make a difference, the adjustable one will make it so you can get it where you want it positioned.
    It’s also totally normal that it would be in a different location because it’s a different shifter.
    98 M3 sedan
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Sounds like you have the wrong parts to start with. A stock selector rod positions the lever in the OE position. Wrong parts or the shift lever is installed backwards.
    Aug 2013
    1999 BMW M3 Coupe
    I haven't installed my EVO3 yet, but from what I can tell it shouldn't really change the resting/neutral shifter position much at all. It reuses the same carrier, their DSSR maintains the same geometry as stock, and the only real new thing is the shape and increased length of the actual shifter lever which serves to shorten the throws. But the shifter itself should still sit in the same place in the car since it's coming up through the same opening and at more or less the same angle and height (unless you adjust it).
    But yeah, an adjustable DSSR like you posted would certainly allow you to set the top of the shifter wherever you like it along the front/rear axis.
    Peoria, AZ
    Quote Originally Posted by Braymond141 View Post
    Bolt is facing front of the car, so I am pretty sure it is installed in correct orientation. Stock shifter carrier... It isn't terribly off, but it is noticeable. I guess I'll try flipping it around tomorrow.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    I'm guessing backwards. Easy to do. I was halfway through the job before realizing it was backwards because of the position.
    Peoria, AZ
    Finally got around to flipping it around and it hasn't made any positive difference. If anything, all forward gears sit even closer to the opening in the console.
    FL
    are slow.
    Hmm.. There is no reason for it to stay off of center. Can you post a picture of the position?
    Are you sure you flipped it the correct way, and didn't flip it twice? The shifter position should change dramatically if you flipped the shifter. See the attached pic. You can see the bend, flipping it would cause it to bend the other way.
    -Dr. Seuss
    Peoria, AZ
    Right, this is exactly what I though, but looking at the bend of my shifter, it isn't as obvious as it is on manual you've posted... I wonder if what I was sold a modified shifter or belongs to a different model altogether.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Did you buy it new or used?
    Peoria, AZ
    Used.
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    That's probably your answer...I've got a UUC shifter in the garage, (I installed a 6 speed trans) Post a pic of you yours.
    Peoria, AZ
    Oh well, for sale it will go I guess... Too bad the seller I got it from neglected to mention this.
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    Yeah, that ain’t right... I don’t know what that’s for..
    Peoria, AZ
    Was able to bend it back with a press at a shop, lever sits perfect in neutral. As a reference, it used to sit few mm from the front of the opening in 1st3rd and 5th. Just need to do the same operation to bring it closer to the left now.
    Is DSSR worth the $?
    FL
    are slow.
    It helps keep things a bit tighter. I think it's a good upgrade if you're looking for a slightly tighter shifter. You should also refresh all of the bushings while in there. I would NOT pay over $100 for any DSSR however, they essentially are all the same. I had the AKG unit and it was well made.
    Offer them $80, or even 90.
    https://www.ebay.com/itm/E36-M3-328-...gAAOSwBFpblpSu
    Garagistic is a decent second.
    https://store.garagistic.com/e36-M3-...sr-25111222738
    Jun 2013
    Bellevue wa
    1998 bmw m3 sedan
    Quote Originally Posted by Hova View Post
    This is what I have, it’s great!
    98 M3 sedan
    Peoria, AZ
    Thank you guys!
  1. UUC * Evo3 shifter promotion valid through 2/16/08 - GET FREE STUFF!
    By Rob Levinson in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 02-20-2008, 07:02 PM
  2. UUC Evo3 Shifter "USSE3"
    By Shady3One3 in forum Exterior Lighting & Body Parts
    Last Post: 12-20-2007, 12:57 PM
  3. It's official: UUC Evo3 shifter fits 550i.
    By Rob Levinson in forum 1996 - 2003 (E39)
    Last Post: 12-21-2005, 07:49 PM
  4. New UUC EVO3 Shifter $250 shipped
    By diffsonline in forum BMW Parts For Sale
    Last Post: 09-25-2004, 06:53 PM
  5. uuc evo3 shifter
    By phily in forum BMW Parts For Sale
    Last Post: 08-03-2004, 07:21 PM
