Results 1 to 5 of 5
Thread: 1997 Z3, 1.9, 5 spd. check engine light on
    Jul 2018
    North Carolina
    1997 Z3
    scanned and it says, "speed sensor". Don't know which speed sensor it's referring too. any ideas?
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by Joetransou View Post
    Both the specific problems and the DTC can point to the sensor responsible.
    Aside from the warning light, do you have any problems, or a specific trouble code from the scan?
    There is a speed sensor on the differential for the speedo, cruise control, volume adjustment on the radio, speed-sensitive wipers, etc.
    There are speed sensors on the wheels for ABS and traction control.
    BMW MOA 696, BMW CCA 1405
    Jul 2018
    North Carolina
    1997 Z3
    The car runs and drives like new. The only thing that don't work properly is the tachometer. When you start the engine it goes to 2400 rpm and stays till you turn the engine off.
    Aug 2012
    Newport UK
    1999 z3 1.8
    Might be an idea to run the hidden instrument cluster test to check all the guages and warning lights are working as they should, running the test will swing the guage needles across their full range, you will see if the Rev Counter is capable of travelling over its full range.
    Link to how to here https://www.zroadster.net/forum/viewtopic.php?t=20201
    Jul 2018
    North Carolina
    1997 Z3
    ran the test and the tachometer stops at 2400 just like when the engine is running
  1. Z3 E36/7 Atlanta 1997 Z3 2.8 5 spd Silver 4.8K OBO
    By Erik L in forum Z3,Z4,Z8 Classifieds
    Last Post: 04-03-2016, 09:16 AM
  2. 1997 bmw 528i check engine light
    By thevault7 in forum 1996 - 2003 (E39)
    Last Post: 02-16-2007, 11:46 PM
  3. Z3 Check Engine Light
    By CAL99 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-05-2007, 09:14 PM
  4. 1997 318i check engine light on again & again....
    By 84 GRANDSPORT in forum 1991 - 1999 (E36)
    Last Post: 09-23-2006, 09:34 AM
  5. Z3 check engine light
    By Maineiac in forum 1983 - 1991 (E30)
    Last Post: 08-13-2006, 01:30 PM
