Results 1 to 4 of 4
Thread: Kicking in when shift D from R automatic transmission M60b30
    Nov 2017
    Bulgaria
    e32 730 V8
    Hello, I have problem on my e32 93’ m60b30 when I shift from R to D there is a hard kick, but when is in driving, everything is ok . There is no faults on OBC.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Troubleshooting BMW A5S 310Z ZF 5HP18 http://www.bimmerboard.com/forums/posts/1214743/
    might need a valve body cleaning and overhaul https://forum.e34.de/thread.php?thre...&hilight=5hp18
    Nov 2017
    Bulgaria
    e32 730 V8
    I had a mistake when I described the problem, when I put on R there is a kick, but harder is when is from D to R. When it’s from P to R or N to R is slight kick.
    I think this is troubleshooting maybe, but can you explain to me what I must change do :
    Hard engaging jolt in position R
    a) Damper of brake D malfunctions
    b) Modulation pressure too high
    c) Wire to pressure regulator faulty
    d) Pressure regulator faulty
    a) Replace valve body, refer to 24 30 006
    b) Replace pressure regulator, refer to 24 34 861
    c) Repair/replace wire harness, refer to 24 35 501
    d) Replace pressure regulator, refer to 24 34 861
    Thank you!
    Jan 2005
    Japan
    Possibilities:
    remove the valve body and clean it and replace all balls in the valve body, disassemble and clean the solenoid valves in the valve body. That usually solves the problem. See the above link I gave for valve body overhaul.
    In addition, for the 5HP18 there was a new EPROM with a new software for the transmission control module, which exactly solves this problem http://www.7-forum.com/modelle/e32/e..._egs/index.php
    Software D3000:
    Symptome :
    - Harte Hoch- und Rückschaltung in verschiedenen Fahrzuständen, schlechter Schaltkomfort
    - Elektronische Getriebesteuerung schaltet sporadisch auf Notprogramm, Fehler 100 (Gangüberwachung) im Fehlerspeicher
    - 3-2 Zurückschaltung unkomfortabel, bei langsamen Gasgeben (35 - 50 km/h) mit starkem Stoß, tritt bei schnellem Gasgeben nicht auf
    - 4-5 Hochschaltung bei Lastrücknahme hart
    - 5-4/4-5 Pendelschaltungen unter leichter Last im Geschwindigkeitsbereich von 80 - 85 km/h
    - Sporadisch harte Schaltung nach abgebrochener Volllastbeschleunigung aus ca. 120 - 155 km/h
    - 4-5 Schaltung wird unter leichter Last im Geschwindigkeitsbereich von 80 - 85 km/h abgebrochen, d.h. es wird kurzzeitig, evtl. mit hartem Schaltstoß wieder der 4. Gang genommen. Dieser Vorgang kann sich bei konstanter Fahrt (80 - 85 km/h) unter leichter Last mehrmals wiederholen (Pendelschaltungen)
    google translate
    Symptoms:
    - Hard upshift and downshift in different driving conditions, poor shifting comfort
    - Electronic transmission control switches sporadically to emergency program, error 100 (gear monitoring) in the fault memory
    - 3-2 dowbshifting uncomfortable, with slow throttle (35 - 50 km / h) with strong impact, does not occur when fast accelerating
    - 4-5 upshifting in case of loss of load hard
    - 5-4 / 4-5 pendulum shifts under light load in the speed range of 80 - 85 km / h
    - Sporadic hard circuit after aborted full load acceleration from approx. 120 - 155 km / h
    4-5 Shifting is stopped under light load in the speed range of 80-85 km / that means it is briefly, possibly taken with hard shift shock again the 4th gear. This process can be repeated several times under constant load (80 - 85 km / h) under light load (pendulum shifting)
    This EPROM is no longer available from BMW. But you can buy it from some people in Germany, for example from the person which made the DIY instruction for the valve body overhaul I posted above in the German E32 forum, his company
    http://www.jozic-automobile.de/
  1. leather shift boot for e36 automatics?
    By Reck1ess in forum 1991 - 1999 (E36)
    Last Post: 05-06-2005, 01:15 AM
  2. E39 Automatic Transmission Shift Console Trouble
    By M51AB in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-04-2005, 11:23 PM
  3. Replies: 5
    Last Post: 09-30-2004, 10:14 AM
  4. WTB: 96+ auto shift shaft and leather automatic shifter
    By mpower325 in forum BMW Parts Wanted
    Last Post: 05-24-2004, 10:02 PM
  5. Shift boot for E36 Automatic?
    By BMW318iS in forum 1991 - 1999 (E36)
    Last Post: 10-05-2003, 03:17 PM
