Results 1 to 3 of 3
Thread: ARC KS 900.6 550W 6-Channel AMP Robert Zeff designed
    Sep 2010
    southern california
    yes
    KS 900.6 - ARC Audio 6 Channel 550 Watt Amplifier
    New in the box with everything $350
    Designed by Robert Zeff
    Description:
    Advanced Microprocessor control system
    Code Based flashing diagnostics for faster trouble shooting
    Optional center channel
    2/4/5-6 channel input options and source selection switches
    Block style terminations
    12dB butterworth crossovers (all channels)
    Front + Rear Channels (High pass and Full Range)
    Sub + Sub Bridged on channel 5+6 (Full Range and Low Pass only)
    Center Channel #6 (Full Range and high pass only)
    Specifications:
    Power output RMS @ 4 ohms: 4 x 60 watts
    Power output RMS @ 2 ohms: 4 x 100 watts
    Power output RMS @ 4 ohms (Sub Channels only): 2 x 155 watts
    Power output bridged @ 4 ohms 2x120 watts: 2 x 120 watts
    Power output bridged @ 4 ohms (Sub Channels only): 1 x 550 watts
    Transient Distortion: < .01% @ 4 ohms
    Frequency Response: 20Hz - 20 KHz
    Signal to Noise Ratio: >77dB
    Bass Boost: +15dB @ 45Hz
    Crossover (Butterworth): 55Hz-5.5KHz var - 12dB
    Fuse: 25A x 4
    Size: 19 1/2"(L) w 8.0"(W) x 2 3/8" (H)
    Sep 2010
    southern california
    yes
    Bump
    Jun 2018
    LA, CA
    1990 325ic s52 swapped
    I sent you a PM.
  1. ARC AUDIO XXD5080 5 channel amp perfect OEM replacement $148 shipped eBay find
    By ClubSport332ti in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-06-2012, 03:20 PM
  2. FS: 95 E34 525i $900/obo Wichita, KS
    By speedlust in forum 5 series & 6 series
    Last Post: 11-30-2011, 10:57 PM
  3. FS: NIB Arc Audio KS 500.1 Mini Sub Amp
    By dinan e39 in forum Car Audio & Electronics
    Last Post: 05-18-2011, 12:08 PM
  4. arc 900.1D
    By hobo9912 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 01-22-2008, 09:35 PM
  5. FS: Phoenix Gold 9.0:5 Octane-R amp 900 watt 5 channel
    By Roffle Waffle in forum BMW Parts For Sale
    Last Post: 10-02-2004, 03:12 AM
