KS 900.6 - ARC Audio 6 Channel 550 Watt Amplifier
New in the box with everything $350
Designed by Robert Zeff
Description:
Advanced Microprocessor control system
Code Based flashing diagnostics for faster trouble shooting
Optional center channel
2/4/5-6 channel input options and source selection switches
Block style terminations
12dB butterworth crossovers (all channels)
Front + Rear Channels (High pass and Full Range)
Sub + Sub Bridged on channel 5+6 (Full Range and Low Pass only)
Center Channel #6 (Full Range and high pass only)
Specifications:
Power output RMS @ 4 ohms: 4 x 60 watts
Power output RMS @ 2 ohms: 4 x 100 watts
Power output RMS @ 4 ohms (Sub Channels only): 2 x 155 watts
Power output bridged @ 4 ohms 2x120 watts: 2 x 120 watts
Power output bridged @ 4 ohms (Sub Channels only): 1 x 550 watts
Transient Distortion: < .01% @ 4 ohms
Frequency Response: 20Hz - 20 KHz
Signal to Noise Ratio: >77dB
Bass Boost: +15dB @ 45Hz
Crossover (Butterworth): 55Hz-5.5KHz var - 12dB
Fuse: 25A x 4
Size: 19 1/2"(L) w 8.0"(W) x 2 3/8" (H)
Bump
I sent you a PM.
