Results 1 to 8 of 8
Thread: Z3M Trunk Lid Panel Retrofit
    Portland Oregon
    '17 330i M sport Touring
    For those of you that retrofitted the deck lid panel did you panel fit correct at all four pinning points? I purchased a panel but only two pins were able to be installed. The two lower I'd need to drill out but not sure I need to.
    How did yours fit?
    '17 BMW 330i XDrive MSport Touring
    '20 BMW R 1250RS Imperial Blue Metallic-Exclusive
    '02 BMW Z3 2.5i Titanium
    Jan 2015
    Larryville
    2000 M Roadster
    I didn't retrofit the trim panel, but my M Roadster trunk lid trim looks like this:
    I suspect the trim panel will start to sag if you don't add the bottom two fasteners.
    You are putting a prefacelift trunk trim panel onto a facelift trunk. it wont fit and I would not drill holes to try to make it fit
    Aug 2017
    The pre-facelift has a trunk trim panel? Another piece that's missing from mine then
    Quote Originally Posted by me77 View Post
    Only M's to my knowledge
    Jan 2015
    Larryville
    2000 M Roadster
    Quote Originally Posted by BimmerBreaker View Post
    It appears to mostly fit, other than the two missing fastener holes; why would carefully drilling (obviously being aware that drilling past minimal depth would perforate the trunk lid outside sheetmetal) two holes for push fasteners be a problem?
    Portland Oregon
    They were only on the "M" version.
    The parts guy at the breaking yard said it was same and I didn't have my Z3 with me at the time.
    I'm certain as you say it's for the earlier version and wouldn't cut holes to fit but would forgo this project if the dealer cannot source the correct part.
    Thanks all!
    Oct 2013
    Augusta, GA
    1999 Z3 M-Roadster, 2007
    Am I missing something here? Why not cut new holes in the trim panel to match the holes in the trunk lid? If you get it wrong it ain't no big deal.
  1. Simple Question for 2006 M5 Trunk Lid Panel
    By bjd10201976 in forum 2004-2010 (E60,E61)
    Last Post: 02-14-2017, 09:25 PM
  2. M Roadster - Wonky Trunk Lid Panel
    By CB750 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-17-2015, 03:46 PM
  3. Part # for trunk lid panel/tool kit clips
    By tekazgtr1984 in forum 1995 - 2001 (E38)
    Last Post: 05-19-2011, 06:52 PM
  4. Replies: 6
    Last Post: 06-17-2005, 12:27 AM
  5. Replies: 2
    Last Post: 08-03-2004, 12:22 AM
