Results 1 to 2 of 2
Thread: LCM change/program F30 328i
    Mar 2019
    Fort Worth, Tx, USA
    2012 BMW 328i Sedan
    Question LCM change/program F30 328i
    Hi I went to the agency and they told me they had to change the LCM (Light Control Module). They were charging me around 1200 dollars for the part and labor which seems excessive. I found the part online much cheaper but can someone explain the process of replacing and programming (if it is needed). If I bought a repair manual would this have the instructions to do it? My car is a F30 BMW 328i 2012
    Thanks!
    Jul 2004
    Houston, TX
    36 Cylinders
    What is your car doing (or not doing correctly) to need that part?
    There is no dedicated LCM on F30....
    It's part of the FEM (front electronics module) which also contains the vehicle security. So you cannot use used parts.
    If it's for the rear lights, then the REM (rear electronics module) is in charge of those.
    I would suggest clarifying before paying for anything. That or find a better shop.
    Can you please confirm it's what you need?
    And no, a manual will not show you any of that, however with good computer skills, you can program one yourself.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. LCM change/program F30 328i
    By rahumen in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-03-2019, 03:40 PM
  2. F30 Camo F30 328i Xdrive
    By lmal355 in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 04-06-2018, 08:19 PM
  3. F30 F30 328i Active Autowerke Signature exhuast
    By timmay77 in forum Engines, Performance Parts & Software
    Last Post: 12-19-2017, 01:11 PM
  4. F30 lowering springs for f30 328i with xdrive?
    By Bmw323!s in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 03-23-2016, 08:36 AM
  5. Video- How to change Spark Plugs in an F30 328i
    By bkeys in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-08-2016, 07:41 PM
