Results 1 to 9 of 9
Thread: E36 Rear Clunk
    Aug 2018
    Watsonville
    97 M3, 97 328i, 95 318ti
    E36 Rear Clunk
    so i can’t seem to get this figured out. my car has been makin this noise ever since i really got it. everytime you let go the clutch and give it gas to go.. it makes a noise that sounds like somethin is movin or piviting on somethin in the subframe area in the back. also when shifting through gears, you can here a thump through every gear, less on the high gears. could this be blown subframe bushings? or something my be loose?
    - 1994 BMW 325i
    Dec 2013
    Chicagoland area
    EXOTICS
    My guess would be possibly worn/damaged shockmounts, giubo/flexdisc, or subframe bushings as you mentioned.
    I would also check for proper differential oil level.
    MDR629 is offline Just Go Faster BMW CCA Member
    Feb 2013
    Philly
    E36 M3, E61 535, E66 760
    Quote Originally Posted by S.C.B.I.M.M.E.R View Post
    - 1994 BMW 325i
    First things that come to mind are to inspect the rear subframe mounts, all three differential mounts, and the front differential mount bolt which are known to break. From there, check the giubo, driveshaft center support bearing, and all rear suspension mounts/bushings.
    Interests include: Any VIN beginning with "WBS", any engine code with a "7" as the second digit, any Individual car, and all things Touring.
    http://www.bavarianspecialties.com
    Oct 2003
    Seattle
    99 M3
    E36 Rear Clunk
    …RSM…then look at RTABs.
    Cracked Giubo (Boschi joint) can do this as well.
    Jun 2016
    California
    E36 325is
    Its 99% rear upper strut mounts. Then check rtabs.
    Sep 2018
    Florida
    1995 325i
    Could possibly be diff bushing.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Tre36 View Post
    …and/or broken Differential Bushing Fastener.
    Jun 2016
    California
    E36 325is
    I'm just waiting for him to come back and tell us it was 1. A torn subframe 2. Shot rear strut mounts... Ohh, sometimes the rear strut to rear hub bolts like to back out... So a dangling strut will do this as well.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    I'm going to say that your front diff bolt is probably the culprit....however, the sound you are describing I also experienced when the diff was about to explode.....pull out the speed sensor and make sure it isn't covered in silver goo.....
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  1. E36 Rear clunking (not subframe, not rtab pocket cracks
    By 3seriescollin in forum 1991 - 1999 (E36)
    Last Post: 10-24-2018, 10:59 AM
  2. Rear clunk e36 not suspension!!
    By Max55 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-30-2009, 10:24 AM
  3. Calling all E36 experts ... unusual rear clunk i can't figure out
    By Lawrence1 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2009, 08:45 AM
  4. E36 M3/4 rear clunk ...can't figure it out
    By Lawrence1 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-25-2009, 02:24 PM
  5. E36 Rear Susp Clunk
    By MikeE36 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2007, 03:21 PM
