Results 1 to 13 of 13
Thread: Options for a Sport Wheel mount/adapter cover?
    Dec 2018
    San Francisco
    ‘81 E21 320i
    I got a wheel in good condition, it needs the cover that goes over the mount bracket. Right now you will just see a metal frame that mounts the wheel to the column.
    What are my options? Is this something that would work?
    https://www.ebay.com/itm/Genuine-Rai...p2047675.l2557
    Vermont
    81 320i, 98 318ti
    No it will not work because what you are looking at is an actual hub adapter the steering wheel screws into. BMW cover is just a cover that goes over the steering wheel hub.
    I think you can get a new cover from BMW or W&N, I recently replaced mine. I also got a new horn button part. I still have the old parts if you are interested but the tabs are broken on the cover and it needs to be attached/glued to work.
    Max
    Dec 2018
    San Francisco
    ‘81 E21 320i
    Wallothsech doesn't have it. Have no idea to find it from BMW. Is there a site for that? I just get new stuff, or dealer sites.
    Jun 2016
    Austin, TX
    1978 323i
    Dec 2018
    San Francisco
    ‘81 E21 320i
    Yeehaw! Yes that's it!
    I just went to that site. I didn't realize there was a sub menu after steering to find more stuff! I missed it. Thanks a lot!
    Max - would your collar make noise if it isn't glued?
    (I'm pretty sure I will remove this wheel at some point in the near future so I don't want to use glue."
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    If it’s new it’ll clip in. Most of us glue the old ones because the tabs are long gone
    -John
    Vermont
    81 320i, 98 318ti
    without the tabs it would rattle. There is a way to tie it to the wheel (mine was attached that way) but it was still rattly.
    Dec 2018
    San Francisco
    ‘81 E21 320i
    OK, I'll get a new one. Thanks for the info guys, and offer, Max.
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    If it does for some unknown reason rattle, a dab or two of black RTV wouldn’t hurt.
    -John
    Vermont
    81 320i, 98 318ti
    The new one won't need anything- it just snaps into place.
    Max
    Jun 2016
    Austin, TX
    1978 323i
    Mine is missing a tab or two and rattles a little. It doesn't prevent you from removing the wheel. I think a few dabs of hot glue or RTV would work fine.
    Dec 2018
    San Francisco
    ‘81 E21 320i
    By the way, what size socket do I need for an E21. I read 22mm for E30 but that might not work for E21. I have an 81
    Vermont
    81 320i, 98 318ti
    deep 22mm, same as for e30.
    Max
  1. AC Schnitzer Wheel Mounting Adapter Package
    By Bamsterman in forum Suspensions, Springs & Shocks
    Last Post: 02-21-2013, 07:30 AM
  2. AC Schnitzer Wheel Mounting Adapter Package
    By Bamsterman in forum Wheels and Tires
    Last Post: 02-21-2013, 07:29 AM
  3. E36 M3/E39 Sport Wheel Leather/Alcantara Cover
    By Xeniczone in forum Interior Lighting & Body Parts
    Last Post: 07-31-2012, 12:41 AM
  4. Replies: 9
    Last Post: 04-26-2008, 11:33 AM
  5. FS: OEM 328is sport wheels WITH tires mounted/balanced
    By M52 POWER! in forum Wheels and Tires
    Last Post: 08-09-2005, 02:32 PM
