Results 1 to 5 of 5
Thread: Differential Oil Cooler
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I am thinking about installing a diff cooler on my car with the 210 mm large case diff, for the hell of it, lol! I live in S. Texas where it gets pretty darn hot and I plan to drive up to Denver occasionally to visit my son driving 15 hours across Texas in the summer heat. Plus I would like to do track events every month or two.
    Achilles Motorsports has a decent looking kit for $600 that uses the fill and drain plug ports for cooler hoses. I might be able to piece together a kit of my own for apprx $400 but they do use a decent quality Tilton pump.
    https://www.achillesmotorsports.com/...m-dock-tru.htm
    Any thoughts or suggestions? Thanks,
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I doubt you need it unless maybe you are running a very short ratio.
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    What's the car?
    On a street car it's not that easy to find a safe location for the extra radiator where it'll both get useful airflow and not risk being wiped out by a dead armadillo or some other road debris. Any chance you're trying to fix a problem you don't have?
    Neil
    96 M3 - Rogue Engineering high capacity finned diff cover
    Vancouver, B.C., Canada
    '97 M3
    I’m half way through making a finned rear cover for a 210 diff in an e36. I just need to make provisions for the VSS.
    Dec 2013
    San Antonio
    I am running a heavy 850i. Car just looks too cool not to drive it at track events occasionally. Maybe I can find an adapter for drain port where I can mount a sending unit and monitor oil temps.
    Chikinhed, that modified cover looks like it will definitely help cool off the case.
    GlowShift sells an bushing adapter so a 1/8 npt temp sensor can be used at the M22 port on the diff. So I will probably by a gauge and adapter and monitor diff temps before I go to the expense and trouble to mount a cooler system.
    https://www.glowshiftdirect.com/1-8-...hread-adapter/
  1. Oil cooler for manual transmission and differential
    By e36monteiro in forum 1991 - 1999 (E36)
    Last Post: 03-25-2017, 03:20 AM
  2. WTB differential oil cooler tube assy
    By kiwiCSi in forum Parts for Sale
    Last Post: 07-26-2016, 05:45 PM
  3. Is an external differential oil cooler overkill for occasional track days.
    By ChristopherG in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-04-2014, 09:14 AM
  4. Rear differential and transmission oil cooler kit.
    By SanderWM in forum Track Car Builds
    Last Post: 01-23-2010, 05:26 PM
  5. Dear/Differential Oil
    By Kritpoon in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2001, 11:54 PM
