I have a 1995 325i vert which I blew a wheel bearing which causes everything in the wheel well to get destroyed. I’ve found a parts car but it’s an 1998 328i vert. I mainly only need the parts that are in between the rear driver side wheel and the diff. I can’t find out anywhere if they are interchangeable. Also will a 1995 325i sedan stuff work in my vert or do I need to stick to verts and coupe for it.
Hard parts such as axles, trailing arms and bearing are interchangeable on for non M3 6 cylinder E36s. Brake rotors are different.
If you need parts I have 10 cars and can supply you with a complete corner for easier swapping. I'm about 1 hour south in Westminster
Greg
410-967-617 zero
