I'm fighting IM readiness for CAT and O2 and have INPA going to look at history and non mil codes as well as Test-o to log the Lambda probes and post cat O2. I do notice post cat bank 1 is sometimes not following bank2 and the lambda probes look good. Also seeing error code P3239 in history, it didn't se the MIL and its definitely since I've clear things. Let me know if you need specific things to log I just focused on the pre and post O2s as they are related to the rediness I'm fighting. Also are these pending codes and hence might effect rediness running?
$SGBD: MSD80 Version: 7.300
$INPA: MSD80 Version: 1.001
$DATAID: 004 4CC0I NA0S IJF5S
=== 09.04.2019 === 12:28:23
DME partnumber: VAR_ECU_SERIAL_ECU
current kilometer reading: 71158 km
__________________________________________________ _________
comment line 1: 3289
comment line 2:
$error locationNr: 12195
$error locationtext: 0x2FA3 Codierung fehlt
610A012FA36800010122A716118F3C027C2C8B000000000000 0000000000000000002804044C918080807F230B00323900
Error: 1(1) No.: 12195 0x2FA3 Codierung fehlt frequency: 1
error type: 8 (4351 ) keine Codierung erfolgt (nach Programmierung)
readines Flag: (16 ) Testbedingungen erfüllt
error status: (35 ) Fehler momentan vorhanden, OBD-entprellt
MIL - Status: (48) Fehler verursacht kein Aufleuchten der Warnlampe (MIL)
P-Code: P3239 Steuergerät Kodierprozess - keine Kodierung F_LZ: 40
ambient text / entry at 70968 km km(1.)
Motordrehzahl 704.00 rpm
Spannung Kl. 87 14.52 V
Status Motorsteuerung SYN_ENG_IGK_ON
Zeit seit Startende 1126.40 s
Freeze Fr.: Zustand Lambdaregelung Bank 1 3 Regelung AUS wegen Fahrbedingung
Zustand Lambdaregelung Bank 2 3 Regelung AUS wegen Fahrbedingung
Berechneter Lastwert 29.7 %
Kühlmitteltemperatur OBD 105.0 °C
Lambda Integrator Gruppe 1 -0.0 %
Lambda Adaption Summe mul. und add. Gruppe 1 -0.0 %
Lambda Integrator Gruppe 2 -0.0 %
Lambda Adaption Summe mul. und add. Gruppe 2 -0.8 %
Saugrohrdruck 35.0 kPa
Drehzahl 704.0 rpm
Geschwindigkeit 0 km/h
F_FLC: 0 F_HLC: 1 F_CLA: 00 F_DLC: 40
diagnostics activ: nicht aktiv diagnostics interrupted: nicht aktiv
MIL Status: nicht aktiv MIL debounced: nicht aktiv
end of cyclus: nicht aktiv user error: nicht aktiv
=== 09.04.2019 === 12:28:45
comment line 1:
comment line 2:
Drehzahl 704.0 rpm
=== 09.04.2019 === 12:30:14
comment line 1:
comment line 2:
Error: 1(10) No.: 12195 0x2FA3 Codierung fehlt
class : 00; frequency: 1; entry at km: (1.): 70232 km (2.): 0 km (n.): 0 km
Error: 2(10) No.: 12195 0x2FA3 Codierung fehlt
Error: 3(10) No.: 12195 0x2FA3 Codierung fehlt
Error: 4(10) No.: 12195 0x2FA3 Codierung fehlt
Error: 5(10) No.: 12195 0x2FA3 Codierung fehlt
Error: 6(10) No.: 12195 0x2FA3 Codierung fehlt
$error locationNr: 12251
$error locationtext: 0x2FDB Kraftstoffhochdruck nach Freigabe der Einspritzung
Error: 7(10) No.: 12251 0x2FDB Kraftstoffhochdruck nach Freigabe der Einspritzung
error type: 1 (4763 ) Druck zu niedrig
error status: (32 ) Fehler momentan nicht vorhanden, nicht OBD-entprellt
class : 01; frequency: 11; entry at km: (1.): 70240 km (2.): 70240 km (n.): 70504 km
$error locationNr: 11566
$error locationtext: 0x2D2E Drosselklappenwinkel - Saugrohr-Unterdruck, Korrelation
Error: 8(10) No.: 11566 0x2D2E Drosselklappenwinkel - Saugrohr-Unterdruck, Korrelation
error type: 1 (4762 ) Druck zu hoch
MIL - Status: (49) Fehler wuerde das Aufleuchten der Warnlampe (MIL) verursachen
class : 56; frequency: 2; entry at km: (1.): 70240 km (2.): 70264 km (n.): 0 km
$error locationNr: 12234
$error locationtext: 0x2FCA Kraftstoffhochdruck bei Freigabe der Einspritzung
Error: 9(10) No.: 12234 0x2FCA Kraftstoffhochdruck bei Freigabe der Einspritzung
class : 01; frequency: 1; entry at km: (1.): 70360 km (2.): 0 km (n.): 0 km
$error locationNr: 12250
$error locationtext: 0x2FDA Kraftstoffhochdruck bei oder nach Freigabe der Einspritzung (2. Umweltbedingungssatz nach Zeitverzögerung)
Error: 10(10) No.: 12250 0x2FDA Kraftstoffhochdruck bei oder nach Freigabe der Einspritzung (2. Umweltbedingungssatz nach Zeitverzögerung)
