Page 4 of 43 FirstFirst 123456789101112131429 ... LastLast
Results 76 to 100 of 1067
Thread: E36 M3, from dual purpose to track only
  1. #76
    Jan 2003
    Free America AZ
    German ones
    Quote Originally Posted by aeronaut View Post
    Fuel expansion tank delete done.
    Summary:
    - removed charcoal canister, and associated hoses/tubes/wires.
    - removed expansion tank
    - there are 3 hoses connected to the expansion tank; to charcoal canister (removed/cut), from fuel tank (to top of expansion tank; plugged), to fuel tank (from bottom of expansion tank; vented through breather filter).
    I routed the vented/filtered hose into truck temporarily. I want to see if it ever fills with fuel. I don't think it will if I never fill the tank. There's zero fuel smell while the car is sitting. I'll eventually move it to the space where the expansion tank was.
    Attachment 662026
    Attachment 662027
    If it does fill with fuel you certainly don't want that in your trunk (or near the battery)! I'd skip the discovery phase and move that guy to the expansion tank location now lol.
    Nice work so far!
    Dave
    '18 RAM 2500 Laramie Cummins
    '15 Pure White VW Touareg TDI
    ///'95 Avus M3 S54B32 Race car -- 2022 ProAutoSports PS1 Champion
    ///'72 Chamonix 2002 (Restoration project)
  2. #77
    Aug 2012
    Central, MD
    1995 M3
    Haha...yea, I thought about that. I'm not tooooo worried.
  3. #78
    Aug 2012
    Central, MD
    1995 M3
    FYI, anything more than about 3/8s tank of fuel, and there's fuel in my vent hose. I thought it'd take more. I may switch the hose/filter to the other hose from the fuel tank, and see if it's better or worse. Then I'll move the filter to the wheel well.
  4. #79
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    A discriminator is going to be your best bet on stopping fuel from flowing through the line. Fuel Safe has a bunch of good stuff in the way of discriminators and check valves.
    https://fuelsafe.com/motorsports/fue...-check-valves/
  5. #80
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by BlackHawkRacing View Post
    Thanks. At that point, I'd just put the evap canister back on.
  6. #81
    Aug 2012
    Central, MD
    1995 M3
    A few little projects, nothing major. A few must-do's over the winter are, install new rear diff, and probably new (rebuilt) steering rack, and any "while I'm in theres".
    But for now:
    Don't need this:
    Deleting and moving some fuses and relays, but need to order some stuff to finish up:
    And, custom fitting my Kirkey (this is why I bought an aluminum seat, so I can get a near perfect fit):
  7. #82
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Wait what? Can you explain what you are doing to your seat? New at the aluminum seat game so excited to hear. I do not believe standard fiberglass Halo seats will work with my cage bars.
  8. #83
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
    I bought a Kirkey 45 Series seat. It fit good, but not perfect. I can TIG weld (by some definition of welding) so it's "easy" to make modifications. So far I've changed the layback by about 10 deg, and added 2" of height between the side supports and shoulder supports, effectively raising the shoulder/head restraint stuff (I'm tall). This second mod also forces me to cut and sew the seat cover. Kirkey sold me some material.
    FYI, Kirkey also makes custom seats. I didn't know at the time, and have no idea how much one would cost.
    Kirkey's don't look sexy, but oddly, they were the most comfortable seat I sat in (trying on a dozen or so). And many of them with HNS are adjustable.
  9. #84
    Springfield, IL
    I love the look of their containment seat on their website. This is definitely the route I need to go myself once I can pull the trigger on re configuring my door bars for ease of access. I am fairly certain Halo seats will ensure I am not able to get into my car, so probably need to figure out something else in the meantime (nets?) that will suffice for HPDE settings.
  10. #85
    Aug 2012
    Central, MD
    1995 M3
    That's an interesting point. I don't have a cage...but I know many that run a cage and containment seat STRUGGLE to get in/out of the car. Seems an opportunity for some company like kerkey to make the left side of the containment system "fold" out of the way for ingress/egress, then easily lock into place for use.
  11. #86
    Springfield, IL
    That would be AMAZING.
  12. #87
    Aug 2012
    Central, MD
    1995 M3
    Just playing with the cut wheel.
  13. #88
    Springfield, IL
    One thing the PO did on my car was removed the retaining clip on the door hinges so the doors could be lifted on and off. It has been absolutely awesome when loading on my trailer and working on the interior of the car to easily pop the doors in and out.
  14. #89
    Aug 2012
    Central, MD
    1995 M3
    Excellent idea!!! Thanks.
  15. #90
    Aug 2012
    Central, MD
    1995 M3
    Fuse box in the engine bay, GONE. (Although there will likely be 3 relays there).
    EVAP canister in the engine bay removed a while back.
    A little more access room in that crowded corner of the engine bay now.
    Lots of wire wrapping and zip tying to do, but car starts and runs with no funny warning lights.
  16. #91
    Aug 2012
    Central, MD
    1995 M3
    Got the seat done (extended 'thorax' area 2").
    Started on removing engine/trans.
  17. #92
    Aug 2012
    Central, MD
    1995 M3
    Discovered this during inspection. Ouch.
    Lesson, don't ignore lifter tick. Oil starvation is oil starvation.
    I think my cams are ok.
    Of course now, the while I'm in there syndrome starts.
    Talked to VAC and Achilles. I will say, the advice from Achilles was simply AWESOME.
    Also, at the end of last season when I rushed my clutch install, and rushed my slave cylinder install, I exploded my slave inside the installed trans. Got all the pieces out, and put in a new slave. Had clutch shudder from the get go. I knew what had happened.
    Brake fluid on the clutch PP, disk, and FW.
  18. #93
    Aug 2012
    Central, MD
    1995 M3
    Follow up on the RTD shifter. I'd still get another one. But....
    It corrodes easily. So I guess I'll have to sweat less.
    I moved my fuel tank vent. Previously, it was to one of those old school PVC filters under the rear wheel well liner. It was dirty under there, and I just didn't like not being able to see some portion of the whole set up.
    So I vented to the filler neck area. And put in a much smaller filter.
    One more thing about the RTD, it binds a bit at each extreme of forward/rear travel. I'm going to get the dremel out and fix this.
    I'm not sure if it travels this far when attached to a transmission, but I'm not sure it doesn't. So I'll make sure this is never a problem.
  19. #94
    Oct 2007
    Louisville, KY
    1995 M3
    The devil is in the details and this build has them all covered!
  20. #95
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by bimmerboy318 View Post
    Thanks! I think.
    Chase Bays power steering reservoir and lines came in.
    Hard to get a picture of the baffling in the reservoir, but it looks to be a small canister shaped cylinder 1.5" tall placed over the inlet.
    And no filter like the OEM, so we'll see how this all works out.
    On initial inspection, seems like a decent kit. We'll see how it fits.
    Waiting for a new steering rack from rackdoctor, arriving Friday.
    Not sure what the two little screws on the back side of the cap are for. Maybe a fluid level sensor that's on some cars?
  21. #96
    Aug 2012
    Central, MD
    1995 M3
    Saw this happen to anther forum member. Paid for an Elring HG. Received a HG in Elring packaging. Got a Victor Reinz.
    WTF?
    What are our choices for head gaskets if no more 'real' Elring? BMW OE is like 3x the price.
  22. #97
    NY
    skateboard
    WTF?
    I’ve been hearing about this happening a lot lately.
    ― George Orwell
  23. #98
    Aug 2012
    Central, MD
    1995 M3
    I purchased from FCPEuro. Oddly, most of their Victor Reinz stuff is a few more bucks than their Elring stuff. So from their viewpoint I got a good deal. I'll call them tomorrow and see if I can get a 'real' Elring.
    I've just not read good experiences from the VR headgasket. But maybe something's changed, or it's just internet lore. Dare I consider a MLS gasket? VAC raves about them.
  24. #99
    Oct 2007
    Louisville, KY
    1995 M3
    WTF?
    That happened to me! I’m also the one that left the review at FCP Euro about it. My car hasn’t left the garage so not sure how it will hold up. I used new BMW head bolts with it. First track day is March 9th for me!
  25. #100
    Aug 2012
    Central, MD
    1995 M3
    It will all probably be fine. Only those with failures report on the nets.
    I will be trying to get an Elring. I guess I'll install the VR if I can't.
  1. E36 FS/FT 1996 E36 M3 SICKTOP DAKAR COUPE HPDE TRACK LI/NY Street Legal
    By Mattyboom in forum Race Cars & Track Parts
    Last Post: 03-04-2015, 02:56 PM
  2. E36 FS: E36 M3 Stock Dual mass Flywheel, Clutch disk, and Pressure plate
    By bladsville in forum Drivetrain & Transmission Parts
    Last Post: 03-01-2014, 01:54 PM
  3. E36 WTB - E36 M3 OEM Dual Mass Flywheel
    By 95RedBMWe36M50 in forum BMW Parts Wanted
    Last Post: 02-11-2013, 01:28 PM
  4. E36 FS: E36 M3 clutch, dual mass flywheel with ~2,000 miles on it
    By G60 CAB in forum Drivetrain & Transmission Parts
    Last Post: 02-08-2013, 09:26 PM
  5. E36 WTB: E36 M3 Stock Dual Mass Flywheel (for S52)
    By m3leistung in forum BMW Parts Wanted
    Last Post: 07-20-2011, 03:00 AM
