Page 3 of 43 FirstFirst 1234567891011121328 ... LastLast
Results 51 to 75 of 1065
Thread: E36 M3, from dual purpose to track only
  1. #51
    Aug 2012
    Central, MD
    1995 M3
    Well, decided to get rid of window motors. This allowed me to remove body electronics control module. Yea! Only computers left are; DME, ABS, and instrument cluster (although I don't need that). Down to 11 fuses!
    I'm keeping the OEM windows and tracks for now. Using a bungie strap to hold them up during transport on open trailer.
    Not that much weight, but getting rid of this stuff feels good.
  2. #52
    Aug 2012
    Central, MD
    1995 M3
    Have decided to make windows removable at the track.
    Working on best way to keep them in place during its time on the open trailer. I-bar or hangers or such.
    FYI, removing coupe door windows and all associated hardware, motors, and wiring saves 40-42lbs.
  3. #53
    Aug 2012
    Central, MD
    1995 M3
    Here's all the hardware for the windows, not including the motors.
    Decided to go with the usual home made hangers for the windows.
  4. #54
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    Did you have to drill out rivets on the mechanism?
    My driver side was held in with bolts but the passenger side was riveted to the door.
  5. #55
    Aug 2012
    Central, MD
    1995 M3
    Yep. Both sides were riveted.
  6. #56
    Aug 2012
    Central, MD
    1995 M3
    Moved my AiM MyChron3 around a bit, made a new switch panel (Kydex), and cleaned up some wiring rats nests behind the dash.
    It feels like the wiring chore never ends.
  7. #57
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Are you towing your car?
  8. #58
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by golgo13 View Post
    Yep. Open trailer.
  9. #59
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    I'm super jealous. I want to remove my glass to save weight.
  10. #60
    Aug 2012
    Central, MD
    1995 M3
    40lbs, sitting there laughing at you.
    (Bluntly, I'm not SURE it's worth it. Pushing a button to raise the window isn't just a luxury.)
  11. #61
    Aug 2012
    Central, MD
    1995 M3
    Deleted the battery jump box. It's the little things.
  12. #62
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Nothing more fun than weight removal. Cheap, makes you faster, makes the car more fun to toss, and easy to tinker with when your bored!
  13. #63
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by olemiss540 View Post
    Exactly!!
  14. #64
    Aug 2012
    Central, MD
    1995 M3
    Got around to:
    - removing sound gunk from rear seat area, and cleaned up / wrapped wiring.
    - re-routing battery wire so passengers won't stomp it (temporary, as I hope to install a light-weight battery to engine bay over the winter).
  15. #65
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Quote Originally Posted by aeronaut View Post
    3 track days on RTD shifter and poly mounts.
    I like the shifter. I'd do it again. But it's not a religious experience. Next weekend I'll be on the track I use 2nd a few times (Summit Shenandoah). So I'll find out if I wish I'd paid for reverse lock-out.
    The poly mounts add tons of NVH, of course, and completely change the engine noise inside the car. But, I now know where a 'clunk' that I've had for over year is coming from. lol.
    How do shifts from 2-3 and 3-2 feel?
    I have the AKG Stage 3 and hate going 3 to 2. (drift car but same rules apply to shifting really.)
    instagram @andyitslit
  16. #66
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by Press22 View Post
    2-3 is good. I'd say 3-2 is better than the previous short shifter I had in there, but if I had reverse lock-out, it'd be even better.
    No doubt, 3-2, and 4-5 are somewhat slower shifts compared to 3-4, and 4-3. But all better than stock or with a SSK.
  17. #67
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    I have the RTD w/ reverse lockout. 3 -> 2 is painless.
  18. #68
    Aug 2012
    Central, MD
    1995 M3
    At last event, 4th gear started popping into neutral. Ug. And for a while, have been wondering where a loud clunk is coming from. Sounds like trans, so I'm hoping it's 'just' the dual mass flywheel. Anyway, picked up a used transmission and bought a gripforce 'stage 1' PP, clutch, and flywheel.
    What happens when you wrap 40lbs of metal in a brown paper bag, and hand it to an angry government worker to carry 3000 mi?
    7 of 8 flywheel bolts delivered, and (luckily, all cosmetic):
  19. #69
    Aug 2012
    Central, MD
    1995 M3
    Update on clutch. from gripforce. Gripforce sent 8.8 grade flywheel bolts that need to be tightened to 105Nm, which is out of spec for an 8.8 grade bolt. Crap.
    Guess I'll order some higher grade bolts from McMaster.
    EDIT:
    For the record,
    OEM dualmass flywheel, 25.0 lbs
    Gripforce single chromoly steel flywheel, 14.5 lbs
  20. #70
    Aug 2012
    Central, MD
    1995 M3
    With the trans out, easy access to those heater hoses that need to go.
    Fabbed up a blockoff plate, installed, and cut the necessary hoses.
    Gonna install a 90 deg fitting to hook up what's left.
  21. #71
    Aug 2012
    Central, MD
    1995 M3
    Ok, I could not find a definitive post on OBD1 fuel evap tank and charcoal canister. Here's what I now know.
    OBD1 charcoal canister above.
    Tube 3: to atmosphere
    Tube 2: from (or to) rear fuel evap tank under rear wheel well.
    Tube 1: to engine throttle body
    Tube 2: to (or from) charcoal canister. It's the bigger of the 3 plastic tubes shown. I assume the others marked F, are fuel in and out of fuel tank.
    So, I've deleted the charcoal canister, removed the blue line (2) as far back as I can (some of it is captured under the rear seat panel). I'm going to connect a filter to the rubber hose that was connected to 2.
    I don't see any reason to run a looped piece of hose as I see some people do, if I'm leaving the evap tank attached.
    If I delete the evap tank, then yea, I guess a looped hose would prevent any fuel from sloshing out. But if I never fill past 3/4 tank, I doubt that would happen.
    I don't see any need for an evap tank if 1) i've deleted the charcoal canister and 2) I never fill above 3/4 tank.
    Make sense?
  22. #72
    Aug 2012
    Central, MD
    1995 M3
    Deleting OBDI fuel expansion/evap tank, or what ever it is. I'll never fill fuel tank above 3/4 full, and charcoal canister already deleted.
    There are 3 lines:
    1) vent line to charcoal canister. (Cut/removed)
    2) Line from fuel tank to expansion tank
    3) Line from expansion tank to fuel tank
    I'll plug either 2 or 3, and vent the one I don't plug. I haven't decided which one is the right one to vent, 2 or 3. I'm not sure it matters. But I'm guessing plug #2, vent #3, because #3 would be located higher in the fuel tank.
  23. #73
    Bergenfield, NJ
    I am OBD II but I went through the same process. On mine there is a breather line that goes from the tank to the top the fuel filler hose; it also had a branch line that connects at the same junction that connected to the expansion tank. I left the main breather and the expansion tank line as is, and deleted/plugged everything else. I then put a discriminator valve on the hose that ran to the expansion tank and ran some extra hose, looped several times, and terminated it in the rear bumper. I also put a crankcase breather filter on the end of the hose.
  24. #74
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by BlackHawkRacing View Post
    I plan to do basically the same. Luckily mines a touch simpler. I'm going to run a line from (my) #2 or #3 to a breather filter, and yea, probably put a few loops in it just in case.
  25. #75
    Aug 2012
    Central, MD
    1995 M3
    Fuel expansion tank delete done.
    Summary:
    - removed charcoal canister, and associated hoses/tubes/wires.
    - removed expansion tank
    - there are 3 hoses connected to the expansion tank; to charcoal canister (removed/cut), from fuel tank (to top of expansion tank; plugged), to fuel tank (from bottom of expansion tank; vented through breather filter).
    I routed the vented/filtered hose into truck temporarily. I want to see if it ever fills with fuel. I don't think it will if I never fill the tank. There's zero fuel smell while the car is sitting. I'll eventually move it to the space where the expansion tank was.
  1. E36 FS/FT 1996 E36 M3 SICKTOP DAKAR COUPE HPDE TRACK LI/NY Street Legal
    By Mattyboom in forum Race Cars & Track Parts
    Last Post: 03-04-2015, 02:56 PM
  2. E36 FS: E36 M3 Stock Dual mass Flywheel, Clutch disk, and Pressure plate
    By bladsville in forum Drivetrain & Transmission Parts
    Last Post: 03-01-2014, 01:54 PM
  3. E36 WTB - E36 M3 OEM Dual Mass Flywheel
    By 95RedBMWe36M50 in forum BMW Parts Wanted
    Last Post: 02-11-2013, 01:28 PM
  4. E36 FS: E36 M3 clutch, dual mass flywheel with ~2,000 miles on it
    By G60 CAB in forum Drivetrain & Transmission Parts
    Last Post: 02-08-2013, 09:26 PM
  5. E36 WTB: E36 M3 Stock Dual Mass Flywheel (for S52)
    By m3leistung in forum BMW Parts Wanted
    Last Post: 07-20-2011, 03:00 AM
