Page 12 of 43 FirstFirst ... 234567891011121314151617181920212237 ... LastLast
Results 276 to 300 of 1067
Thread: E36 M3, from dual purpose to track only
  1. #276
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    Very nice! What did you use to cut the hood? I have to do this myself soon.
  2. #277
    Aug 2012
    Central, MD
    1995 M3
    From the top side, Dremel style tool with metal cut disks worked pretty well.
    For cutting the bracing on the bottom side of the hood, I used a 5" angle grinder with a metal cut blade.
  3. #278
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Quote Originally Posted by aeronaut View Post
    Car weighed on scales at track.
    Car empty (measured weight minus my weight and minus 6lb/gal of gas) = 2,380.
    I was surprised.
    This is very light! My car is 3,000 w/ driver and full tank but I have a lot of HPDE amenities still.
  4. #279
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by golgo13 View Post
    Gotta commit to get light!!!
    I've done all the cheap/easy stuff (remove, cut, trash), but little of the harder (eg expensive) stuff. EG, all my windows are still glass, but I pull out the 2 door windows.
    I keep eyeballing those rear quarter windows.....I know HardMotor has a solution. But I'll re-engineer something, spend a few weekends on it, buy 3x the material, cut myself and need stitches, and say "thats ugly". And then buy the HM windows.
  5. #280
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Yeah, my brother-in-law has a GTS3 or GTS2 NASA E36 car and when he saw I still had A/C and the HVAC blower/heater core he goes, "So, you're not really all that serious about weight reduction."
    I will say that he has a trailer and a tow vehicle whereas I don't have the money or space for one.
    I've been considering plastic windows as well, just not sure what works with the OEM window regulators and is the best for scratch resistance. I want to do the quarter windows as well, since those seem "easy" as a starting point.
  6. #281
    Aug 2012
    Central, MD
    1995 M3
    Many of us were at your point for a long time. I'd just say if you're still driving to/from events, weight reduction will be limited.
    I wouldn't move to plastic windows in a car that needs to be driven to/from events.
  7. #282
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Highway wind an issue?
  8. #283
    Aug 2012
    Central, MD
    1995 M3
    Just for example, none of the plastic windows are designed to be rolled up/down. And there's no window frame so opening/closing door requires extra steps if window is in place.
    Rear qtrs and rear window would probably be fine. Making them waterPROOF might be a challenge, and something that would need addressed every year or so.
  9. #284
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Yeah, sounds like a problem. Any idea of the weight of each window vs plastic?
    The rear window and rear quarters could be done I guess. Though, the nose is where all the weight is on this platform haha
  10. #285
    Bergenfield, NJ
    There is a sizable weight savings going to plastic from glass but pulling the motors and associated hardware is where the real savings come in. That said, as aeronaut said, the plastic windows are a bit of a hassle for a street car. Only plastic/lexan items I have seen that look like good solutions are all permanent installs that don't roll down. Not a problem in Europe but since we have to keep out windows down, it's not feasible.
  11. #286
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    I'm open to also doing the rear and quarter windows to save a few lbs?
  12. #287
    Aug 2012
    Central, MD
    1995 M3
    I'd guess that would save about 10lbs total.
    Big weight reduction is in the stuff that keeps the car comfy and quiet. Seats (front are 60lbs each), rear seat, back, and belts are around 100lb IIRC. And ohhh, all that carpet and sound deadening, and the sun roof. Those items, plus HVAC, are the big ones. Every thing else is nibbling around the edges.
  13. #288
    Aug 2012
    Central, MD
    1995 M3
    Stuffing some 255/70's onto my 8.5" rims and gonna see how I like them.
    So, gotta make room.
    My math says I needed 8mm more clearance on the outer rear fender. Every where else should fit.
    Cut, hammered, rolled, pulled (sounds like pork BBQ!):
    Attachment 677614
    Attachment 677615
    Attachment 677616
  14. #289
    Mar 2017
    Oahu / Los Angeles
    S54 E36
    Pics aren't showing up?
  15. #290
    Aug 2012
    Central, MD
    1995 M3
    Hmmm, not sure what's up with that. They were loaded by bimmerforums, not linked. Trying again....
  16. #291
    Sep 2016
    WI
    01 330Ci
    Decided to install aerocatches.
    This is just orange tape, but will probably paint them fluorescent.
    The idea being, if down all good. If up I can see them from drivers seat.
    Unfortunately, the aerocatches have a "almost down but not secured" position.
    I just must never put them in that position.
    Pretty good idea, might have to do that with mine.
  17. #292
    Aug 2012
    Central, MD
    1995 M3
    Decided to go with yellow paint.
  18. #293
    Aug 2012
    Central, MD
    1995 M3
    I ordered the wrong fuel safety vent from Radium (they sent the one I ordered, but their web page was messy and I ordered the wrong one).
    Rather than return, figured I fab something up. So for about $70, I should be good to go.
  19. #294
    Jul 2014
    metairie, la
    1999 e36 M3
    Strange that some cars seem to have issues puking fuel. With the setup I posted above (loop of hose and $5 fuel filter), I can fill my tank completely and not spill a drop
  20. #295
    Aug 2012
    Central, MD
    1995 M3
    Agreed! Mine is showing no signs of leakage up to a little over 1/2. But at 3/4, there is some.
    Installing valve this week for the upcoming weekend at PittRace!
    Changed my setup last week, now on 255/40-17s (toyoRR), 650F/800R springs, etc.
    It's all an experiment.
    I see 1.6 lateral G in the carousel on Summit Shenandoah. Got a little rub in right rear. A few spots of very light rubbing fender liners in fronts. All fixable with a hammer and a torch.
  21. #296
    Oct 2007
    Louisville, KY
    1995 M3
  22. #297
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by bimmerboy318 View Post
    Are you running the stock DME on OBD1?
    Yep.
  23. #298
    Aug 2012
    Central, MD
    1995 M3
    Had several issues with the MRT roll center correction kit.
    Lot's of details here:
    https://www.bimmerforums.com/forum/s...-Experience(s)
    Now installing the SLRspeed kit. Overall, better. But, I did have a few issues. But, the guys at SLRspeed were VERY responsive to my issues and questions.
    On first install, SLRspeed kit had this problem:
    An email and a few phone calls, SLRspeed sent new outer pins (just in case something was wrong) and different spacers (which they felt was the real problem).
    Shorter spacer compared to original spacer provided:
    Now, were at:
    Even the SLR guys are a little confused as to why there aren't more threads showing, but I'm pretty sure this will be fine, this is 14.5mm thick locking nut, and normal nuts are 13mm thick, so I know enough threads are captured for strength.
    Installed:
  24. #299
    Aug 2012
    Central, MD
    1995 M3
    Playing with camber, camber shims, and GC camber plates today. Decided to repair the bolts on the locking thing on the GC plates. 3, M8 bolts tack welded into the frame. Cut, removed, replaced, and TIG'd back in. Front camber now set at -4deg. But, 95 spindles and GC 'street' camber plates force me to use about 5mm thick shims to get to -4 deg.
  25. #300
    Aug 2012
    Central, MD
    1995 M3
    Fuel filling started acting very weird last event, sometimes backing up into the fill tube and cutting off the fill.
    I check the fuel discriminator valve from Radium Auto, and the plastic float ball was swollen and sticking. Jeeeezzzus.
    Looked for a replacement, and ended up with some Al hollow spheres from McMaster.
    Oversized swollen plastic (about 0.8") vs Al hollow sphere (0.75", which is the same diameter as the heavy solid up-side-down cut off ball):
  1. E36 FS/FT 1996 E36 M3 SICKTOP DAKAR COUPE HPDE TRACK LI/NY Street Legal
    By Mattyboom in forum Race Cars & Track Parts
    Last Post: 03-04-2015, 02:56 PM
  2. E36 FS: E36 M3 Stock Dual mass Flywheel, Clutch disk, and Pressure plate
    By bladsville in forum Drivetrain & Transmission Parts
    Last Post: 03-01-2014, 01:54 PM
  3. E36 WTB - E36 M3 OEM Dual Mass Flywheel
    By 95RedBMWe36M50 in forum BMW Parts Wanted
    Last Post: 02-11-2013, 01:28 PM
  4. E36 FS: E36 M3 clutch, dual mass flywheel with ~2,000 miles on it
    By G60 CAB in forum Drivetrain & Transmission Parts
    Last Post: 02-08-2013, 09:26 PM
  5. E36 WTB: E36 M3 Stock Dual Mass Flywheel (for S52)
    By m3leistung in forum BMW Parts Wanted
    Last Post: 07-20-2011, 03:00 AM
