Results 1 to 4 of 4
Thread: 328i Lambda probe heating error code
    Jan 2016
    Spain
    E39 530i
    I´ve got an issue with my 1996 328i OBD I (European spec). Almost a year ago I plugged INPA to my car and pulled a error code "25 Lambda probe heating Probe 1". Analog Values 2 graphics showed that, while oxygen sensor 2 voltage oscilated between 0-5 V, oxygen sensor 1 voltage always stayed in the 4,80-4,90 V range. The car drives fine (although since I bought it 4 years ago the engine, frankly, doesn´t seem anywhere as creamy as I expected a in-line six should be, or as my E39 530i), idles perfectly, good performance and fuel economy.
    Yesterday I had the annual inspection and it failed the smog test, the CO values were very hign and worse in the second try than in the first one. This afternoon I´ll plug INPA again but it seems the oxygen sensor 1 need replacing.
    Question is, is it advisable to replace both oxygen sensors or replacing only the bad one will be enough? OE BMW or a NTK sensor is fine? Very difficult to do? I suppose that if it´s screwed in the header the cold/hot temperature changes will make it hard to remove.
    Thanks a lot.
    Jun 2010
    NY
    1997 328i
    Yes replace both, NTK/NGK/Denso. It's not a hard job, but there is a tool that assists in getting the old part out. You should also use injector cleaner every so often. Here in the US we have a product called CRC GTP that will help clean the system out (crc guaranteed to pass, google it). If you can't get it then just run a quality product over a couple tanks of fuel, use good gas. You should drive a couple tanks of gas with cleaner before re-testing.
    search ebay "oxygen sensor tool". I don't know what size it is though.
    Jan 2016
    Spain
    E39 530i
    We have CRC products over here but I´ve never seen CRC Guaranteed To Pass for sale. I could try and use a good injector cleaner like Liqui Moly´s, and see if I´m lucky in the smog test, but if it fails I would have to pay the inspection test cost again. It´s not very expensive but it´s about half the price of a new NGK oxygen sensor, so the sensible thing seems to replace at least the bad one.
    Thanks!
    Jan 2016
    Spain
    E39 530i
    New oxygen sensor installed, I passed the smog test with flying colours. Great!
  1. INPA Lambda probe heating error
    By B234R in forum 1991 - 1999 (E36)
    Last Post: 05-03-2018, 04:44 PM
  2. Replies: 4
    Last Post: 04-02-2018, 07:16 PM
  3. Lambda Heating Probe 2 Error! Wont go away!
    By MisterM52 in forum 1991 - 1999 (E36)
    Last Post: 07-27-2016, 02:15 AM
  4. 2003 530da: Error code 4587 - ´heated fuel filter'.
    By bmwjavier in forum 2004-2010 (E60,E61)
    Last Post: 12-22-2011, 07:55 AM
  5. error code 191 heating problem ,lambda probe
    By koziolek in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-14-2010, 09:41 PM
