Results 1 to 7 of 7
Thread: Drivetrain Malfunction/ Significant Loss in Power
    Apr 2019
    Fayetteville, NC, USA
    2012 BMW 528i
    Lightbulb Drivetrain Malfunction/ Significant Loss in Power
    Hi everyone, I have a 2012 BMW 528i and it's been dependable for me for the most part; However, recently I received the infamous "drivetrain malfunction, drive moderately" message. The car now has a slight shake when idling and their has been a significant loss in power. Also there is a slight delay when cranking. I had the spark plugs, fuel injectors, fuel rail and coils replaced but this did not solve the problem. Does anyone know what this could possibly be? I just want to get answers before taking it to the local bmw dealer and spending $150+ just for a diagnosis. Thanks in advance!
    Jun 2008
    Dallas, Texas
    '14 550/M, '03 540/M
    Quote Originally Posted by kclark55 View Post
    well..if you have an OBDII code reader that works on BMW's that would most likely tell you what's wrong...without that, it's difficult to guess. I would have said fuel injectors, but you said those are already replaced so..
    Nov 2012
    New York
    2011 535i xDrive
    Quote Originally Posted by yodamel View Post
    +1...I’m no mechanic but before I spent money on any of that, I would’ve diagnosed it first. For all you know, all of those things might not needed to be replaced. The BimmerLink app in conjunction with any compatible Bluetooth OBDII scanner would be your friend in this instance. Good Luck!
    Feb 2008
    orlando
    535i
    i would highly recommend get a ENET cable and ISTA+ and read the error codes. hopefully you know the approx mileage on the car when the error came in. when you read the codes you will be able to see at what mileage the error came in. this will give you an indication on what is wrong.
    also check your coolant tank reservoir...believe it or not but if its low it can cause errors so make sure you top it off.
    Feb 2008
    orlando
    535i
    One more important thing I forgot to mention is check your battery voltage. These cars have lots of modules which depends on good battery voltage and are very sensitive for voltage drop so a low battery will trigger issues and take your car in limp mode.
    If you battery voltage is low then most likely that’s the issue but by just swapping the battery won’t fix it.
    You will have to program the battery (very easy if you have the cable and software) and also clear any codes generated.
    Feb 2008
    orlando
    535i
    Did you ever find a fix for it...I’m curious if it’s your VANOS
    Dec 2019
    atlanta
    2011 BMW 535i xDrive
    I had the same issue, had multiple parts replaced:
    intake manifold gaskets, fuel sensors, MAF, spark plugs, coils, etc. Problem still persisted, did a smoke test and found a TINY leak on the valve cover. Mechanic didnt think that would be the problem, but we replaced the cover & gasket and its been running smooth ever since. no codes.
  1. 530i significant loss of power, Cylinder 1 burning fail
    By nasco in forum 1996 - 2003 (E39)
    Last Post: 09-24-2018, 05:39 PM
  2. F30 2014 BMW 328xi Drive train Malfunction and loss of power in steering
    By BimmIt in forum 2012-2019 (F30, F32, F33, F34, F36)
    Last Post: 11-08-2015, 08:12 PM
  3. Significant loss of power starting at 2000rpm yet no error codes?????
    By nomadic80 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-30-2013, 04:58 AM
  4. M Coupe with significant but intermittent power loss on some starts
    By iPhoneEngineer in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 08-31-2012, 09:13 AM
  5. Just got, Engine malfunction loss of power
    By gbreeE90 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-19-2010, 08:06 PM
