Results 1 to 3 of 3
Thread: Help with fuel cutoff (?)
    Jul 2017
    Marlton, NJ
    E36 325i M3 Conversion
    Had a weird problem at the track yesterday. Car was running a bit hot, but nothing crazy. Once I got about halfway into each session it started severely cutting down/off the power at EXACTLY 5000 rpm's in 5th gear. Once I climbed to 5100 power returned. This happened over and over all day, eventually I started noticing the same in 4th gear but at 6000 rpm's. I'm assuming this is some kind of fuel cutoff.
    I am far from a mechanic, so please feel free to tell me the most obvious of things I should be checking. Any help is appreciated, everything I know about the build is below from a previous for sale listing:
    https://www.bimmerforums.com/forum/s...e-Car-For-Sale
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    fuel filter, failing pump, ignition coils. Did your speedo act up at all? Could also be speed sensor …
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Jul 2017
    Marlton, NJ
    Quote Originally Posted by ScotcH View Post
    Thanks for the response, that makes you the second person to bring up the fuel pump. I just don't get how that would lead to this much consistency in the behavior (5k rpm in 5th every dam time). Speedo did not act up that I noticed, of course I was on track so not watching it heavily.
    I called active who makes the chip and the lead engineer "guessed" at a crankshaft sensor. I know the common issues with that would cause it to have starting issues, I didn't experience that at all.
  1. e46 fuel cutoff every cylinder? HELP!
    By itslaf5 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-17-2016, 01:33 PM
  2. "Misfire Cyl#6, fuel cutoff" issues at the track, help
    By Apiindy in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-19-2009, 07:34 PM
  3. Urgent Help: how do turn off fuel cutoff
    By pak in forum 1991 - 1999 (E36)
    Last Post: 12-04-2003, 11:40 PM
  4. cHECK ENGINE LIGHT ? AND FUEL CUTOFF IS AT 5500, HELP
    By E36Fossy in forum 1991 - 1999 (E36)
    Last Post: 10-07-2003, 01:55 AM
  5. Need help diagnosing fuel/ignition problem
    By traqrat in forum 1983 - 1991 (E30)
    Last Post: 10-03-2002, 03:12 PM
