Results 1 to 3 of 3
    Mar 2019
    CA
    2011 X5 35d
    X5 35D Proper Fuel Supply Pressure
    Does anyone know the target Fuel Supply pressure for a 2011 X5 35D? NewTIS shows 3500-3800 mBar but other areas say 4.1 Bar and others at 5 Bar.
    Had the 4BDA in the past and it came back. I check the supply side and it is around 3700 mBar. New Controller, Pump, Filter. Rail pressure vs. expected is always perfect.
    Since I cleared it last, I have not had the code but it would be nice to confirm the actual limits.
    CHeers,
    Oct 2017
    VA
    1998 328i, 1990 Spec E30
    I dont know the spec, but the X5 has a low side fuel pressure sensor that the 335 does not have. Your sensor could be going bad.
    Mar 2019
    CA
    2011 X5 35d
    Quote Originally Posted by Renzo520 View Post
    Thanks for the note. Yes I have learned a whole bunch about the differences between the X5 35D and 335D. Your 335D utilizes volume supply not pressure supply like the X5. The fuel module can operate in 3 modes, Volume (Measured by RPM), Pressure (mBAR), or Static. Lots of great information out there but some of it is conflicting.
    If I look at this: (Says 4.1 Bar)
    https://www.newtis.info/tisv2/a/en/e70-x5-xdrive35d-sav/repair-manuals/16-fuel-supply/16-14-delivery-preparation-content-measurement-control-units-electric-fuel-pump/6LXaDcb
    But here I get 3700 mBar (3.7 Bar)
    https://www.newtis.info/tisv2/a/en/e70-x5-xdrive35d-sav/repair-manuals/13-fuel-preparation-control/13-31-fuel-pump-with-drive-line/6OeEYmw
    Then in other documents it states 5 Bar.
    Right now I at idle get the 3700 mBar and I don't seem to drop below that but somehow I got the 4BDA code for the supply side.
    It would appear the truck thinks that the current value is fine because:
    1.. The Engine ECU sends a command to the Fuel Pump module to keep the supply side at something.
    2.. The Fuel Pump module then sends a voltage with pulse modulation to the pump. Right now I am getting 3700 mBar but the module is sending between 9-10V to the pump, which tells me it is getting what it expects because it could ramp the voltage higher if it was not supplying what it expected.
    All in all, it is frustrating because I just need the values to know what is normal and what the expected range is.
    Cheers,
  1. 320D N47 Fuel Pre-Supply Pressure
    By razirafi in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-22-2024, 03:56 PM
  2. X5 35d Fuel Pump
    By MacTapatalk in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 10-24-2020, 12:24 PM
  3. where is the BMW E53 X5 3.0d Fuel rail pressure regulator sensor
    By baconbuttyman in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 03-16-2017, 05:04 PM
  4. fuel supply line-no good
    By tybmw in forum 1992 - 1999 M3 (E36)
    Last Post: 08-07-2003, 07:55 PM
  5. Is the gas cap the only way to lose fuel tank pressure?
    By geha13 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-10-2003, 05:16 PM
