Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: E38 740il no power to the pedal
  1. #26
    Apr 2019
    North Carolina
    Bmw e38 740il
    Quote Originally Posted by Sundaycruzer View Post
    Or these
    awesome I’ll try that this afternoon. I was told by two abs module re builders that the Bosch 5.0 cannot be re built. So I pulled a used one off a 740 at a junkyard. But I’ll try this before I put it on
  2. #27
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, second set of pictures 12 and 2, same connectors and can easily be swapped over as they are physically close to each other. The engine does not rev up as the main throttle position sensor does not come off the idle stop - and the ASC+T system sees the secondary throttle move as if by itself!
    My BMW Repair YouTube Channel
  3. #28
    Mar 2013
    Sonora, ca
    2001 740il
    So did it work?
  4. #29
    Apr 2009
    Houston, TX
    2001 BMW 740iL
    That worked for me tonight!
    I replaced a dead battery and the car worked fine for a few weeks and then suddenly went into limp home mode on the dash board and wouldn't rev up and then would start but not continue running.
    I followed Timm's voo-doo procedure here and it worked! The car started and runs fine now!
    Thanks Timm!
    <GRIPE ON>
    That is so annoying. How much would a trip to the dealer have cost me for them to do that procedure? Something that simple should be in the owner's manual and the dashboard should guide you to it. The computer knows what's wrong, this is a common fix, it should all be smart enough to get you going with you have to pay $400 to the dealer for a literally two minute and 5 second procedure. Also it's so great to have Timm here to give us authoritative advice like this, but alarming that so many previous posters would weigh in before anyone would post such a simple and obvious solution.
    <GRIPE OFF>
    Anyway, now I am so happy, I do the dance of joy! Dah-dah-dah-dah-daaaah......
    Certainly worth a throttle reset using the following procedure:
    Get in the car and shut the doors
    Turn the ignition key to position II - but don't start the car
    Press the throttle to the floor and keep it there for 5 seconds
    Turn the key to the off position but do not remove the key
    Let go of the throttle pedal
    Wait 2 minutes without fiddling with anything
    You are now ready to go, start the car and see if all is well.......
  5. #30
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Another happy customer!
  1. 2001 BMW E38 740iL power steering problem
    By adamyansam in forum 1995 - 2001 (E38)
    Last Post: 09-25-2014, 11:25 AM
  2. E38 1999 BMW E38 740il Whole & complete for parts
    By apacect in forum Whole Parts Cars
    Last Post: 07-13-2012, 12:47 AM
  3. E38 Parting 95 E38 740iL
    By ClarkWGriswold in forum Whole Parts Cars
    Last Post: 04-05-2012, 05:30 PM
  4. E38 Various parts wanted! 1996 E38 740iL
    By sigtwenty in forum BMW Parts Wanted
    Last Post: 11-21-2011, 06:33 PM
  5. E38 E38 740iL 740i Brakes/Wheels/Tires $500
    By learsrx in forum Brake Kits, Rotors & Pads
    Last Post: 09-28-2010, 01:19 PM
