Results 1 to 2 of 2
Thread: Front Tension Strut Bushings Replacement
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    I recently replaced the front tension strut bushings on the e83, overall a fairly simple job with a press. Symptoms of worn tension strut bushings can be wobble of steering wheel at speeds from 45 to 65, loose play in steering, increased road noise (similar to a bad wheel bearing), and wandering over bumps.
    The job took about 2 hours to accomplish, steering and road noise restored to factory fresh!
    Raise Car / Supplement with Jackstands / Remove Tires
    Remove front under pan, and front wheel liners / front liner supports. (while under the car, I discovered that its time to replace the oil filter housing gasket)
    Remove inboard bolt and ball joint from knuckle. I chose to leave the ball joint attached to the tension strut arm to avoid tearing the ball joint boot during separation. The ball joint attaches to the knuckle by two external torx bolts. Once the arm/ball joint are removed the bushing is pressed into place.
    The part needed is: 311 203 0 78 82
    Once the vehicle is re-assembled, it is essential to tighten the front cross bolt with the bushing pre-loaded under the vehicle's weight, not with the suspension hanging.
    Hope this helps.
    Regards,
    Brian
    Cave Creek, AZ
    Mar 2019
    ATLANTA GA
    456 X3s
    Good info...I'm going to keep this one for future reference...wish I had visuals of some sort.
    Thanks for sharing.
    Sent from my SM-J727T using Tapatalk
  1. Replaced tension strut bushings today
    By JimLev in forum 1996 - 2003 (E39)
    Last Post: 04-04-2019, 11:03 AM
  2. Front Thrust Arm Bushings Replacement DIY-Pics
    By PENER in forum E39 Common Problems and DIY Fixes
    Last Post: 12-22-2010, 06:12 AM
  3. Front Sway Bar Bushing Replacement
    By mebirkle in forum 1992 - 1999 M3 (E36)
    Last Post: 12-15-2008, 03:56 PM
  4. Front upper strut bushings?
    By 1996 328ti in forum 1991 - 1999 (E36)
    Last Post: 03-23-2008, 02:12 PM
  5. Replacing front upper strut bushing
    By 2DR Vette in forum 1992 - 1999 M3 (E36)
    Last Post: 06-22-2006, 03:48 PM
