Results 1 to 6 of 6
Thread: Control Arm Identification
    Jan 2016
    USA
    1995 M3 Coupe
    I need help figuring out if I have the correct control arms.
    Car is a 95 M3. I have close to one degree of caster difference and I'm trying to rule out mismatched control arms.
    I've measured what i can on both and haven't been able to draw conclusions from that. Anyone able to ID these based on markings? None of the numbers seem to match any control arm part numbers for the E36.
    Left:
    Right:
    Any help appreciated!
    Aug 2011
    WA
    '97 BMW M3/2/5
    Not sure if this will help, but I believe non-M e30's and the '95 e36 M3 have interchangeable control arms. e36's newer than '95 have a different geometry. Maybe try cross referencing some e30 control arm part numbers.
    Feel free to ask about my car:
    TRM Coilovers 560f/784r | Epic Motorsports Tune | Apex Arc-8 17x9.5 et35 | Wilwood SL-4 BBK
    M50 Manifold | ASC Delete | Dinan BBTB | Fan Delete | Power Pulleys | Dinan CAI |
    S54 Oil Cooler
    Z3 Rack | Crossbrace | 3.38 LSD | Dinan Strut Tower Brace | AKG Chassis Mount Shifter
    SS Long Tubes | SS Race Exhaust |
    LTW Replica Wing | MM Underpanel | CF Sunroof Delete
    OE GT Front Splitter | Rear Rollbar | Rear Seat Delete | BW Fuel Starvation | Turtle Labs Door Panels
    And Really Old Paint
    Check out my YouTube channel for more DIY's and videos about my E36 M3
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Actually, it's the E30 M3 arm that's interchangeable. But they are aluminium and are really a race car part, and should be replaced every two years on a E36. And yes, the non M E30 cars are the same geometry as the 95 E36, but the ball joints are not as robust as the E36 M ball joints. Yes you can press in E30 non M ball joints into the E36 arms... (probably a good idea to use the HD ball joints.
    Jan 2016
    USA
    1995 M3 Coupe
    Thanks for the cross reference idea. Spent some time on real oem but cant seem to find any e30 or e36 part numbers that match up with anything stamped on my control arms. I'll keep digging around in the meantime.
    <95 M3 arms 31122227249 & 31122227250
    96+ M3 arms 31122228461 & 31122228462
    Non-M arms _31126758513 & 31126758514
    My hunch would say the side with increased caster is running a 96+ arm
    PRICE CUT on ALL FABRICS
    Jan 2016
    USA
    1995 M3 Coupe
    Yeah definitely could be. Just dont really have a way to know for sure beyond getting a new arm and testing it out.
  1. Need help with part identification near control arms
    By prodigyplayer in forum 1996 - 2003 (E39)
    Last Post: 02-23-2014, 07:14 AM
  2. HELP!!When do I know if control arm bushings need replacing
    By bimmermike in forum 1991 - 1999 (E36)
    Last Post: 06-07-2001, 10:11 AM
  3. How many labor hours to replace lower control arm bushings?
    By Kritpoon in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2001, 01:41 AM
  4. how easy is it to replace control arm bushings?
    By joeyc in forum 1991 - 1999 (E36)
    Last Post: 03-10-2001, 02:04 PM
  5. Control Arms and bushings...
    Last Post: 03-06-2001, 12:37 PM
