Hi
So, my power tailgate will go up but when it gets to the top the motor still winds for a bit - then will not come down. BUT if I stop it going to the top with button it will power down!?!
I kind of thinking it is winding too far when it gets to the top & if it is possible on these early e61 to adjust opening height??
Any help really appreciated
i can adjust the height in my 08. it was both under my CCC and now CIC.
G~
Check this thread out on tailgate issues - a common problem with our E61's has been low hydraulic fluid - and its a quick check to see if that may be the case for you. This morning I followed the process in the link below and it solved all of my tailgate issues - incredibly helpful. Good luck
https://www.bimmerforums.com/forum/s...-opening-fully
