Results 1 to 6 of 6
Thread: Is my gas line loose
    Oct 2018
    Oxnard, CA
    None
    Cleaning my engine bay I notice that there is a lot of play in the gas line connection to the fuel injector rail, is this normal.
    First picture pushing the line,
    Second picture is pulling the line.
    There is like 1/4 gap/play in the line.
    Is this normal.
    Thank you
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    at least tell us model, year engine and complete the profile
    My Cars : None
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Is it leaking? That connection looks similar to the one used on the M54 engine. It’s ok if it can slide a bit.
    Michigan
    2005 325Xi
    Yes, normal. The seal is circumferential to the metal line, so the connector's placement horizontally on the line isn't important, so long as it's locked in place.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Oct 2018
    Oxnard, CA
    None
    It won’t let me put my car info in my profile,
    2006 Z4 3.0i. N52 engine.
    No leaks, I guess is normal based on responses.
    I’ll keep checking,
    Thank you
    Jan 2005
    Japan
    Try again, the model details you can add under settings on top right, not under "my profile".
    Helps us to help you.
    A profile picture is not yet possible, needs more posts.
    I will now move the thread to the Z4 forum from General BMW
  1. Gas door loose
    By Flavcool in forum 1991 - 1999 (E36)
    Last Post: 07-28-2010, 02:54 AM
  2. intake manifold removal, gas lines?
    By anylouder in forum 1991 - 1999 (E36)
    Last Post: 06-06-2005, 08:08 PM
  3. Gas line from cold start valve
    By oldskool3 in forum 1975 - 1983 (E21)
    Last Post: 02-14-2005, 12:51 AM
