Hi guys,
Just got myself a set Azev wheels for my E30 sedan. It is a 17x8.5 ET13. I think it's a 5 series spec. Why this wheel? Coz first of all I like the design and, personally, I think they suit E30. And also they are pretty affordable. This one is new old stock item.
But I think I'm gonna run in a bit of trouble. Looking at the spec 17x8.5 ET13, do you think I can fit these without widebody?? I dont mind massaging the fenders since my car needs a paint job. Any suggestions and opinion?
Sent from my POCOPHONE F1 using Tapatalk
I know on 15x8 et0, I had to roll the fender lips to smooth the inner ridge and it still rubbed on hard bumps in the back. you are only going in about .5 inch from what I had, but your rim is .5 inch wider, so I imagine it will need rolling and will hit on bumps, also
No e30s again.
When I first upgraded to 17x8.5 wheels square on my vert with H&R Sport/bilstein sport combo and 215/45 tires they rubbed in the back with passenger. I rolled the fenders and it went away. In trying to square up the sidewalIs and eliminate stretch, I went to 225/45 tire. The rub came back with a passenger and/or very hard bumps so I added E36 spring pads in the back and it went away. The pads added some rake at first but they settled just right for me. The pads also seemed to improve the front end grip. After the springs settled into the pads , it only rubs on very hard bumps and it just skims the tire for a second. Before the pads it sounded like my rear fender was going to rip off. My main problem now is the front wear at the outer edge of the tires from hard turns. So 215/45 is probably the most tire you can run in the front. The stretch from the 215 is just about perfect to prevent the uneven wear. I may experiment with an equivalent 40 or 35 series tire or just go back to the 215/45s all around.
Bryon
Sent from my iPhone using Tapatalk Pro
