I am curious which would be easier on the engine or if they would be equal:
E85 S52
-Stock compression
-unopened long block
-500whp precision 6262
Pump 92octane S52
-lowered compresion with cutring and spacer
-Stock long block
-500whp Precision 6262
E85 is basically 100+ octane
Stock motor cutring e85 arp.
Or do low compression and flex fuel.
500whp on pump and 600whp on e85.
1989 535i - sold
1999 M3 Tiag/Dove - sold
1989 535i - sold
Uhm, replace the HG. I mean it would suck if you somehow screwed up a perfectly good running S52 unless you like spending money. Poping a HG with boost sometimes does not end well.
Before I speak, the only person I'm aware of that has actually put this into practice is Someguy2800
https://www.bimmerforums.com/forum/s...ock-headgasket
But in my mind: It would probably be easier with a slightly bigger turbo. Really it's going to come down to efficiency. A 6466 would be awesome, and land you right in the middle of the efficiency range for it, though lagier than the 6262.
ARP studs would need to happen. This really isn't an option. If you want the stock gasket to stay in place, you'll need these.
There's no reason you couldn't hit 500whp on E85 with the stock compression and head gasket, but you're playing with borrowed time.
-Dr. Seuss
A 850 rwhp turbo to make 500 rwhp would not be my first choice.
Are we racing stoplight to stoplight?
Or 60 mph ---> 168 mph?
-Dr. Seuss
