I have been trying to code my E60 M5 for aux input. I thought a finally got it going yesterday but now my display shows all groups but nothing works. The error message is no response from control unit so the module is dead. I have found several threads with this code but no answers except for take it to the dealer.
Somewhere along the way I read about a way to recover a module but I can't find it now. I would like to fix my module and know how and why. I'm sure it's just a matter of getting the coding back in but I'm not sure of the steps?
01' 750il Chromeline
95 M3 LS swapped
07 M5 Manual
06' M5, Spartan wheels and a 507hp V10
00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
00' 323i wagon for daughter
03' 525i wagon for the wife, sold
98' 740i for the daughter, wrecked
92' 525i with over 200k, wrecked
02' R1200 CLC, hit by a bus and broken in half. That one made the news!
It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
Well good news, bad news. I went out this morning to try and recover the I-drive I guess you would call it. When I turned the car on the I-drive was working.
I started over trying to code in the AUX input. I checked the FA order and the aux was there. I tried to read the CAPPL with the original daten files and got the same error as before. Then I switched the daten files to the ones I got from bimmergeeks. I was then able to read the CAPPL. I used NCS dummy to mount the Aux input. Then I went back to NCS and coded in the aux input. I got and incomplete error and figured I was screwed. I shut the car off and turned it back on and the aux input was listed.
So here is the new problem. The car says the SOS isn't working and although I can select different inputs including FM there is no audio output. So the saga continues?
95 M3 LS swapped
07 M5 Manual
I feel like such a dumbass. I pulled an old IPOD input module from behind the glove box over a week ago. I just put it back in and now the audio works. In my defence the car is new to me and has a bunch of audio stuff that I haven't figured out yet. It has an Audison controller in the armrest that isn't hooked up to anything and I also found some FOCAL amps in the left rear quarter panel.
So the Aux input is still there and now I'm trying to get it to connect to my phone.
I wish I could give a solid answer as to why the I-drive quit and I got the 2020 code. I guess this will be another thread that ended well but no real answers?
95 M3 LS swapped
07 M5 Manual
